Go to Post H.A.T.E.R.S. = Having Anger Towards Everyone Reaching Success - pandamonium [more]
Unread 15-05-2007, 22:56
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Rookie Year: 2000
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
What rugged sensors do you use?
This season our team had issues with sensor durability. The Vex ultrasonic sensors (or any others) didn't hold up well with colliding robots (even with the sensors themselves protected). Momentary switches wired to the Program/Reset pins on the RC caused resets when high-G forces were encountered. On the other hand, the Greyhill encoders worked well as long as side-loading of the shaft was avoided and the encoder itself well protected. Magnetic proximity switches worked much better than limit switches used in previous seasons.
What experience can you share from your build season? Are there any makes and models you've used that are superior that you can share with the CD community?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 16-05-2007, 07:30
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: What rugged sensors do you use?
To name a few, the parallax ultrasonic modules are very robust and lasted even when perched atop the first extension of our elevator. Also, the US digital analog encoders were much more durable than expected despite their small size.
Above all, if you ever need a multi-turn analog pot, Vishay's are unbelieveably durable... we had one accidentally take the torque of the elevator comming down when a set screw was set wrong, and amazingly it still worked!
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
What sensors do you use? StevenB Programming 18 06-04-2006 23:33
Is there a restriction to what sensors we can use? Robot Dude 0101 Kit & Additional Hardware 28 11-01-2005 22:43
POLL: What sensors do you use Rickertsen2 Technical Discussion 10 28-11-2004 14:46
What view do you use? Brandon Martus CD Forum Support 10 02-12-2003 17:32
What do you YOU use your bins for? AlbertW General Forum 40 13-04-2003 04:18
