Go to Post In most cases on FIRST robots, we have more material than in we need in some places and less than we need in others. That single phenomenon is the leading cause of robot failures. - Paul Copioli [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 23-05-2007, 03:14
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
text in inventor
How would I make letters out of a set width (for a an 1/8" endmill), in a part.
I want to take a 1/4" thick plate and put writing about 1/32" deep in it.
Thanks
Unread 23-05-2007, 05:16
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Re: text in inventor
The best way I've found to add text and extrude it is the emboss tool. First make your plate, then do the text on top, then emboss the text. Good luck getting the right font width, though, I have no idea how to do that.
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 23-05-2007, 11:06
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
All you have to alter the text for a bit is that after you extrude, find all the corners and fillet them to the bit size. Also make sure no gap is less then the bit can fit through. Hope it helps, bye.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 23-05-2007, 13:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Your CAM software will probably have a better tool for this I'd imagine.
Unread 23-05-2007, 22:35
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
i would have to agree with the post above mine. the cam software we use (edgecam) has a built-in lettering feature and provides you with better options than inventor does.
Unread 23-05-2007, 22:39
AdamHeard's Avatar
Lead Mentor
anyone know if MasterCAM has this feature?
Unread 24-05-2007, 14:03
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Yup.
Any major CAM program should have such a feature.
2001-2004: Team 100
2006-Present: Team 254
Inventor help: Text won't show up RogerR Inventor 2 08-03-2007 10:24
Animation text Josh Goodman Rules/Strategy 0 08-01-2007 23:26
Embossing Text Into Parts with Inventor Andrew Blair Inventor 4 30-10-2005 12:47
Text Plugin for Inventor 5 sanddrag Inventor 1 20-01-2004 22:11
Inventor text 157#1Driver Inventor 1 22-02-2003 17:38
