Go to Post The most important things for a team to take to any competition are a sense of humor, a big bottle of Advil, and a camera! - Rick TYler [more]
Unread 23-05-2007, 16:48
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
TTL serial max power
ok Im working on something and I need to know how much power the TTL serial port can put out. basicly the question is weather or not I can run several (2+) microchips off of that +5v. but if I could get a # that would be great.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 23-05-2007, 17:00
karlcswanson's Avatar
karlcswanson karlcswanson is offline
FRC #0111 (WildStang)
karlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nice
Re: TTL serial max power
I think the 5v on the RC can supply 1 amp, that is shared by all of the devices in or plugged in to the RC.
+5V Power Pin - The total combined current supplied from all 16 Analog and 18 Digital +5V Power header pins is 1 Amp. The 1 Amp max can come from a single +5V Power pin.
http://www.ifirobotics.com/rc.shtml#Specifications
Unread 23-05-2007, 17:15
Stuart's Avatar
#include coffee.h
awesome!
Unread 23-05-2007, 21:30
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Yea but that doesn't mean you can safely pull an 1 amp through the chip. if the TTL serial port is connected to the uC then you can only source ( or sink ) as much current as a general IO pin because that is basically what the pin is.
-John
Unread 23-05-2007, 21:46
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
I wouldn't worry too much about the safety of this....
For instance, if you short out a +5v pin and a gnd pin on a Digital I/O (for example), all that happens is the RC Hardware light comes on. It doesn't break anything. It just won't work.
My 2 cents.
Jacob
Unread 24-05-2007, 21:43
Stuart's Avatar
#include coffee.h
no I was just looking for an answer over 100ma. I dont plan on running close to an amp.
Unread 26-05-2007, 01:12
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
If you look in the data sheet look at the max sink/source per I/O and that is your answer.
-John
Unread 26-05-2007, 04:13
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
I think he is talking about the +5V that is available on that pin, not the actual TTL lines themselves. That +5V pin is tied directly into the 1A 5V bus in the RC.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Noisy power supply interfers with rs232/ttl Mike Mahar Programming 1 27-01-2007 22:02
2004 Edubot Serial String Help (TTL in) Josh Siegel Programming 6 10-12-2006 08:28
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
TTL Serial Port and PS2 Mouse Interface cbolin Electrical 8 29-12-2004 15:00
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
