Go to Post The key is to get the WHOLE TEAM to understand that you are designing and building a robot, which is a complete system - not just a collection of mechanical assemblies stuck together. - SteveGarward [more]
  #31   Spotlight this post!
Unread 25-05-2007, 02:16
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Re: Cooling A Room
Well, it sounds like this one is well on its way to being solved. But why not throw in another option...
Growing up in northern BC, I had the exact opposite problem... my room was in the basement and it was too cold. Just to clarify... in the deepest, darkest, depths of winter we would have 1/4" or more of frost in some locations on the INSIDE of the house. (specifically a small location on the north side where the floor joists met the wall and the insulation was thin... it wasn't a complete igloo...) Unlike the multi-server set ups discussed here that might have helped warm the room, my Commodore 64 wasn't exactly dumping a lot of waste thermal energy.
Of course the issue wasn't that the room was too cold... the issue was that I was too cold (the room, really, didn't care what the temperature was).
The solution was to get a waterbed. It was always cozy warm when I went to bed, and not only would it keep me warm in winter, but it was cool in summer. The normal temperature for a waterbed is 28-30 degrees celsius, so unless your room exceeds that temperature on an average basis, you probably won't even need to cool the bed.... which you can do with just a bit of tap water if you need to.
It won't be much help when you're sitting in front of the computer on a hot afternoon, but at least it will help you sleep at night.
Stay cool,
Jason
P.S. Do you have a CRT monitor in your room? This would be a GREAT excuse to get an LCD... and Core2Duos are known for being energy efficient...
P.P.S. The winters in Dawson Creek (my hometown) have been, on average, much warmer over the past couple decades. Even back in the 80's I did a science fair project showing that the winters were warming and snowfall was reducing. Now, due to warm winters across northern BC the Mountain Pine Beetle (which needs three weeks below -30 degrees to kill it) is enjoying exponential growth, devastating huge areas of forest. Anyone who doubts global warming is welcome to drive through the centre of the province and check out all the red, dead trees. So I'm really pleased to see that everyone is suggesting energy/carbon efficient solutions here.
  #32   Spotlight this post!
Unread 25-05-2007, 14:59
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
Re: Cooling A Room
I once had a brick house where the bedroom wall was exposed to the sun nearly all day. I would hose that side down in the late afternoon to cool it off. I was going to build an arbor and plant some vines on it, but I moved before that happened.
You already have good advice on airflow and insulation.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
  #33   Spotlight this post!
Unread 26-05-2007, 16:59
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Cooling A Room
some simple steps -
be sure the air inlet has a clear path (no furniture, clothes, chairs, etc blocking the path.
be sure there is an air return path. if there is not a return in your room -
either keep the door open, or install a return.
if the air return is in the hallway (common) - add a vent above your door into the hall. this can be pretty simple - cut a hole in the drywall on both sides and just install grilles over the cut-outs. you can do this for less then $20.
for the cool air to come in, the warm air has to get out.
* this is why a lot of very old, high ceiling homes have small "windows" above the doors. these could be opened to allow air to circulate through all of the rooms, even with doors closed. i will remember what they are called at some point.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
DIY water cooling Morenoh149 Chit-Chat 2 28-02-2006 23:44
Cooling the Drill Motors Kevin A Technical Discussion 5 11-02-2003 09:32
Water cooling? kc8nod Motors 12 08-02-2003 10:17
Cooling Drill Motors archiver 2001 5 23-06-2002 23:48
Air Cooling Jordan A. Technical Discussion 23 06-02-2002 21:39
