Go to Post I would say FIRST is quite an addiction.............but one of the BEST addictions you'll ever have. - RoboMadi [more]
Unread 27-05-2007, 21:26
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
pic: What are we up to this summer...
Unread 27-05-2007, 21:29
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
Team Role: Leadership
Rookie Year: 2007
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: pic: What are we up to this summer...
good luck! also you could probably use a gyro mounted to measure the z-axis to keep it stable. may i also suggesy building a Legway (lego segway - google it, theres a few links) to prototype to make sure you have a lot of the bugs worked out before you build it full-scale. theres nothing worse than making something to have it not work....
Unread 27-05-2007, 22:54
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
That sounds like a pretty sweet project, keep us posted on how it goes
Unread 28-05-2007, 00:56
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Are you using a ground plane with this board? There is no trace for gnd visible. If so, make sure you select the correct options when you send it to be made. Also, you may want to trim the board down and reduce some of that text, boards get pretty expensive pretty fast as they get bigger.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 28-05-2007, 09:12
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
Oops: Yes, there is a ground plane. I turned it off so I could see what I was doing, but it fills everywhere inside the green outline and all the pads that look like they aren't connected to anything are on that plane.
As for the cost, www.33each.com is my new favorite fab place. $33 boards up to 60 in^2 with no minimum quantity for students. Plus, they send you free popcorn and a Domino's coupon.
Anyone know if the Schottky diode in series (D1) approach is okay for reverse polarity protection for something like this? I'm looking to protect the sensor - the PIC and radio are relatively expendable. Are there any other good methods of making sure the sensor (bottom right connectors) doesn't get toasted?
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 11-06-2007, 20:34
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
Works like a charm. Um, not the Segway part yet, just the PCB. I can grab the 3-axis gyro and accel measurements off the sensor at about 300 samples per second and drive two PWMs, plus communicate everything to a PC wirelessly.
Hooking up the $275 sensor for the first time was scary. No matter how many times you check the pin diagram, it's still an adventure.
Unread 19-07-2008, 15:29
laurita laurita is offline
laurita is an unknown quantity at this point
Smile Re: pic: What are we up to this summer...
Dear Sirs:
My name is Laura Andrea Gonzalez, I am student of engineering.
I am working with the ADIS16350 inertial sensor and a dsPIC microcontroller programmed in MPLAB C-30.
Please, can anybody help me with some C code example algorihm about how can I to build the SPI sensor data aquisition?
Thanks in davance.
Laura
pic: THRUST 1501 Thanks Sponsors this Summer Chris_Elston Extra Discussion 6 26-06-2006 21:58
What are everyones summer plans? Ashley Christine Chit-Chat 31 02-07-2005 23:48
What cool thing have u done this summer? DarkRedDragon Chit-Chat 45 21-08-2003 14:39
What are teams doing in the summer? Tytus Gerrish General Forum 44 12-08-2003 17:37
What has everyone been up to this summer? Marygrace Chit-Chat 1 29-07-2003 16:31
