Go to Post I guess Team 999 was like "Chute first, ask questions later". - KPSch [more]
Go Back   Chief Delphi > Other > VEX
Unread 01-06-2007, 01:31
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Vex Transmitter Disassembled
Okay, so I've disassembled my extra transmitter in under 30 minutes. What I've found are a lot of wires, several boards, and buttons. All packaged neatly in one transmitter. However, upon disassembling it I now have a mess of not-so-random electrical parts on my desk. I can definitely understand how they sell these for $100. Good thing I've got Ebay.
I used four basic tools: three sizes of phillips head screwdriver and some snips.
You'll need to snip the wire that goes to the power plug-in and some glued clips. Also, when removing the trim buttons, you'll need to snip away a chunk of the outer casing, a dremel might work for this but I don't recommend it.
*WARNING: Disassembling the transmitter voids the warranty.
Here are the picture links... there's a lot of steps in between the photos.
http://i10.photobucket.com/albums/a1...648/Vex046.jpg
http://i10.photobucket.com/albums/a1...648/Vex047.jpg
http://i10.photobucket.com/albums/a1...648/Vex050.jpg
http://i10.photobucket.com/albums/a1...648/Vex053.jpg
http://i10.photobucket.com/albums/a1...648/Vex055.jpg
http://i10.photobucket.com/albums/a1...648/Vex056.jpg
http://i10.photobucket.com/albums/a1...648/Vex058.jpg
http://i10.photobucket.com/albums/a1...648/Vex059.jpg
http://i10.photobucket.com/albums/a1...648/Vex057.jpg
As you can see in the last photo, there is the cut away part I referred to. It was kind of a hassle to cut it out but it needed to be done. I also hope that that large board that was over the processor(?) was just a protective piece, I had to cut it off to get to the very last screw hidden underneath, otherwise I can probably re-solder it back on.
Again, don't do this without prior knowledge of what you're doing. Tomorrow I'm gong to mount this onto some plexiglass and a project casing. I'll customize the buttons/joysticks later.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 01-06-2007, 01:43
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Vex Transmitter Disassembled
did you see the new issue of Servo magazine? what a coincidence!
Unread 01-06-2007, 03:01
Go VOLS!!
AKA: Budda648
no team (QC Elite)
No, I didn't. I've never read Servo. Maybe I should pick it up. Where would I get it? What's the coincidence? Did they take one apart, too?
Do The Tyler!
Unread 01-06-2007, 10:35
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
I think those links are bad. I can't open them using Firefox2 or IE7.
Eric Haskins KC9JVH
Unread 01-06-2007, 12:06
Go VOLS!!
AKA: Budda648
no team (QC Elite)
They should be fixed now. What I had done was used the HTML tags from Photobucked instead of the URL link.
Do The Tyler!
Vex Transmitter sale. Gdeaver VEX 2 11-02-2007 21:01
Remote controller transmitter giving us a hard time vivek16 General Forum 2 06-02-2007 20:56
Vex Transmitter problem TheOtherGuy FIRST Tech Challenge 3 21-07-2006 17:01
transmitter question??? mechanicalbrain Control System 1 23-04-2005 16:55
FM radio transmitter Alexander McGee Electrical 11 29-10-2003 19:41
