Private bot - which PIC microcontroller?
Hi there.
as you all know.. the season is over and if you can't get a job.. summer vacation can be boring ![]() SO => ME => BUILD ROBOT! I'm quite new to microcontrollers.. but I think I have enough experience for what I wan to do: a simple robot.. operated using onboard-buttons. but I'm not so sure which PIC microcontroller is best for the job. so.. from your experience.. what fits best? requierments: the ability to provide 4 small DC motors (I'll get those later) EEPROM - important! and that's about it.. thanks again.. Ran. |
Re: Private bot - which pic?
I suggest getitng a VEX controller instead, lots less frustrating for a first project. PICs are a summer project in themselves, without a robot.
Don |
thanks for your reply,
actually, my plans are to play with regular pics this summer, but as I'm a bit limited, I would like to know what are your recommendations. cheers, Ran. P.S do you have experience with PICs? |
I suggest if your going to get started with PICs is to play around for a couple weeks with a 16f628a and a programmer,and a bunch of leds. Try finding a copy of Picbasic Pro, it basically allows you to program a PIC like a basic stamp, so you don't have to worry about all the C syntax.
Re: Private bot - which PIC microcontroller?
If you know C then you can probably start with 18F series and use MPLAB and the C18 compiler to get started. Get a cheap programmer from sparkfun.com.
You can use the 2004+ RC code as a guide for developing your own. All 18F series have the same core structure, just different hardware peripherals. |
www.machinescience.org has a great set of tools for PIC programming based on the PIC 16F877. I think you can still get free FIRST accounts for their web-based IDE. They've streamlined a lot of the programming by having a bootloader and serial programmer, similar to how the FRC controller works, but the microcontroller is fully-functional and you write code for it just like you would in any other development environment.
What are you using to drive the DC motors? Edit: http://www.machinescience.org/firstoffer.html Last edited by ZZII 527 : 17-06-2007 at 16:32. |
I believe the 16f84 and 16f877 are the 2 good begginer PICs. But why a PIC? Why not an AVR? or a BASIC Stamp?
I know from expirience it is much much easier to start with an AVR. it is the same thing as a PIC but made by atmel and not microchip. You can go get a programmer for 50 - 80$ if you want the best cheap board. if you wanna go cheap you can easily go to 20$ for the programmer. the compilers are free, ad there is even a huge underground world for AVRs.......www.avrfreaks.net -John |
hi, thanks a lot for your replies.
(sorry it took me so long to respond).. so, I got my hand on a cheap Microchip PICKIT2. + a bunch of 16f690s. played a lot with it, and currently learning the basics of PWM signals. ZZII, I had no idea that there are offers like this, what does this offer actually provide? forwarded it to me "superiors" John, thank you, looks cool, but too late for me. thanks a lot!! Ran. Last edited by 3dude_2231 : 04-07-2007 at 19:13. |
i'm working on avrs (specifically the 169, as found in the butterfly) for my summer project. butterfly is a nice $22 board with a screen, speaker, etc., plus open-source starter code for all of the built-in functions. you don't need an expensive programmer, just solder up a three-pin connector to serial (i can send you in the right direction if you decide to go this route). AVRs are more powerful and built for C, while PICs are generally built for Assembly, which is a pain and not really relevant to FIRST at all (I hope).
Hope this helps! |
#10
I would recommend an Arduino, It is a little board with an ATmega8 or 168 and a built in programmer, so you get it and its ready to work. There are USB and serial versions. All of the code open source and you program it in C. It supports everything you need it to do.
#12
yeah, i know that feeling. BUT if you have some pins lying around and you know how to use a soldering iron, it isn't really THAT bad.
#13
http://smileymicros.com/ The arduino is nice. It is basically the BASIC Stamp of the AVR world. I looks like you can only program it using the "arduino language" which to me is not good. It is better to learn how to do it right the first time. I also can't find a price for it. The stk and dragon are nice, but they are nor rally made to be put onto a robot. They are good to use as a ISP programmer if you have a seperate board with ISP headers, or if you have a chip that needs to be flashed then put into a socket somewhere. But I have found that with my STK since it has no holes and no other good way to mount it anwhere that I use it strictly for a dev. board. -John |
#14
<picrant>Its good you chose a PIC microcontroller over an AVR or Freescale etc. If you want to drive a victor from the PIC you can run your signal STRAIGHT OUT OF THE MICRO thanks to the high drive currents from PICs... AVRs n such need emitter/follower amplifiers to drive victors.</picrant> Another question, these motors your driving, Are you using your own PWM board? or are you using a drive of some sort? ? Are you using the onboard ECCPs in hardware PWM mode or are you doing it in software? Thanks, -q |
#15
I got to play with a PIC18F452 in an embedded controller class in college -- we built everything from a TRIAC circuit to an alarm clock to a Ford Escort ECU manipulator.
I've also read specs that on of the 16-series PICS is used in the original XBOX as an encrypter/decrypter. Lots of fun stuff to do with a PIC, though the external platform interfaces are becoming outdated. |
| pic: Team 241: This Years Bot Lifting Last Years Bot | Dantvman27 | Robot Showcase | 3 | 21-02-2007 07:04 |
| Embedded Microcontroller major? | John Gutmann | Career | 5 | 27-07-2006 23:49 |
| Propeller Microcontroller | Adam Y. | Electrical | 4 | 20-04-2006 13:27 |
| 217 Vs. 229 - Which Bot is Prettier? | Swan217 | General Forum | 73 | 02-12-2005 13:30 |
| microcontroller selection¿ | Rickertsen2 | Programming | 11 | 25-05-2003 10:52 |
