Go to Post Is there a way to spotlight an entire thread? - ctt956 [more]
Unread 21-06-2007, 14:16
Devo1098 Devo1098 is offline
FRC #1098
Devo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really nice
FP motor differences
i think the different fisher price motors and power ratings is getting confusing
does anyone have the performance curves for the fisher price motors number
00968-9012
00968-9003
and 74550-0642 (this is a weird one, it has a smaller gear on the motor than the 9012)
these motors are from a couple years ago and thats the number on the metal sleeve.
as i believe the 9012 is the most powerful?.
i need at least a different curve for the 9003 and 9012 to decide on the best one for my mini bot application.
Unread 21-06-2007, 14:52
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Team Role: Coach
Rookie Year: 1996
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: FP motor differences
The 9003 and 9012 motors are almost identical in performance, but they have a notable design difference. The 9012 motor has a current limiter built in (I think it is a thermistor, but I'm no electrical guy) that limits the current under high loading conditions. The 9003 motor does not have this feature.
For performance numbers on both motors check out the "motors" forum and look for the thread about 2006 KOP motor stats as both types were provided in the kit last year.
We accidentally got the 9003's in our kit this year and built and tuned our system using them. At our first event we swapped in the 9012 motors and everything worked exactly the same. Unless you are interested in/worried about the current limiting feature, I would consider the motors the same.
RAZ
Unread 21-06-2007, 17:22
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
The current limit is a thermal breaker. It will open when it achieves a certain temperature. This will occur by the passing of a high current or from external/internal heating from the motor and surroundings. Once it has reached trip temperature and cooled, it is more likely to trip again. Many teams experienced this phenomena during arm build and test this year.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 22-06-2007, 06:52
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
This zip has the data sheets that you are looking for.
http://www.chiefdelphi.com/media/papers/1895
Mark
Brick walls are for other people. - Randy Pausch
Gender differences study Emily Pease Chit-Chat 14 14-03-2005 11:11
Differences programming ADXRS150EBs to BEI Gyrochips? Salik Syed Programming 22 17-03-2004 00:47
fcvt and itoa differences? Adam Shapiro Programming 4 19-01-2003 17:09
Differences from the weekend archiver 1999 3 23-06-2002 21:55
Differences in Source? Adrian Wong CD Forum Support 1 27-05-2002 20:23
