Go to Post What’s in a name? That which we call a robot, by any other word would smell of magic smoke. - Jack Jones [more]
Unread 29-08-2001, 16:14
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
Exclamation Gear Ratio Doesn't Matter
I just thought I'd stir up the pot a bit to start the school year. when dealing with drive trains, gear ratio does not matter.
Over the past 2 years, a lot of questions regarding drive trains and gear ratio have been asked. Very rarely do I see mention to the wheel diameter wrt gear ratio. Gear ratio doe NOT matter.
Here's the proof:
Problem: Robot with mass, m; climbing up an incline, theta; on Earth (I threw that in for you NASA guys).
Assumptions:
1. 2 wheel drive (only to simplify the example)
2. Bearing friction and gear train friction negligible.
3. Coefficient of friction high enough to sustain wheel force.
Symbols:
g - Earth's acceleration due to gravity (9.807 m/s^2)
Fat - Total force at wheels (N)
Fa - Force at each wheel (N)
Rw - Wheel radius (m)
Tw - Torque at wheel output (N-m)
GR - Gear ratio = input speed/output speed (usually >1)
Tm - Motor torque (N-m)
Wm - Rotational motor speed (rad/s)
Vl - Linear robot speed (m/s)
1. Total force at the wheels
Fat > m*g*sin(theta)
2. Force at each wheel
Fa > {m*g*sin(theta)}/2
3. Torque at wheel output
Tw = Fa*Rw
4. Torque at motor (or drill motor housing output):
Tm = Fa*Rw/GR --> M*g*sin(theta)*Rw/(2*GR)
Motor torque depends on the wheel/gear ratio combination.
5. Rotational Motor Speed/ Linear robot speed
Wm = Vl*GR/Rw --> Vl = Wm*Rw/GR
Motor speed is inversely proportional to Rw/GR
As we can see from the two equations, a balance between speed and push/pull force must be met. In order to increase pulling force, we need to reduce the torque seen at the motor by reducing Rw/GR. In order to increase linear speed based on a limited motor speed, we need to increase Rw/GR.
For the reasons stated above, many teams are going to a gear shifting design (led by 45 and others). This enables you to optimize for both situations a little better. My stand on the shift v. no-shift is to pick the single best Rw/GR ratio and not shift, but depending on future games my position may change at any time.
I hope this clears up the significance (or insignificance) of gear ratio when dealing with a drive train. So for those of you with a 2:1 gear ratio using the drill motors in low speed, don't think you did anything wrong; but if your wheel diameter is 20 inches with a 2:1 ratio, then you might be in trouble.
I hope this sparks some interesting debate.
-Paul
confuzzling gear ratio definition.. wanna clear this one up? archiver 2001 5 23-06-2002 23:13
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Shifting Gears -- Anton Abaya Technical Discussion 26 22-01-2002 21:49
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
