Go to Post Point is, there is no definite answer. This is FIRST, Whatever works well with your team is the best. - NelsonMichael [more]
Unread 28-06-2007, 19:26
Devo1098 Devo1098 is offline
FRC #1098
Devo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really nice
Victor 884
Does Any one know if a victor 884 can take 24 volts, or even 14.4 volts?
and would the current ratings drop at a higher voltage?
Devo
Unread 28-06-2007, 19:31
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
Team Role: Mechanical
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: Victor 884
the victor 884 can take up to 15 volts @ 40 amps
Championship - Delphi "Driving Tomorrows Technology"
Unread 28-06-2007, 19:35
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
Team Role: Leadership
Rookie Year: 2007
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Victor 884
ya...dont overpower it...our team has done it twice and it aint pretty
Unread 28-06-2007, 20:20
Unsung FIRST Hero
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Victor 884
I speculate it also doesn't smell very good.
In 2006, team 177 was in a frenzy after our first match on Einstein because we thought we had blown a Victor. There was an awful smell, most of our Victor fans weren't spinning, and there was what we thought was a smoke-smudge on the top wall of our controls panel.
It wound up that a tread from the opposite alliance had gotten sheared, causing the smell, but we didn't find out until afterwards. It's scary when you're trying to diagnose a problem in 5 minutes, and need your robot to do 110% on the field in the next match.
Unread 28-06-2007, 21:11
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: Victor 884
You could buy 885s. http://www.ifirobotics.com/victor-88...r-robots.shtml
Eric Haskins KC9JVH
Unread 28-06-2007, 21:35
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Re: Victor 884
Originally Posted by EHaskins View Post
Or 883s
If you have 883s around the shop, you can probably use those, but I would contact IFI to make sure your 883s are to the same specification as the new 883s.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 29-06-2007, 07:51
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Victor 884
Devo
24 volts NO but 14.4 yes. Remember that a fully charged competition battery fresh off the charger can be well over 13 volts. The MOSFETs are rated at 30 volts Vdss but the onboard voltage regulator might not be able to handle the additional input voltage. IFI does make a 24 volt version of this device, hence the 885 part number.
Al
WB9UVJ
www.wildstang.org
________________________
Victor 884 problem Gal Longin Control System 11 26-01-2005 00:47
Victor 884 problem Gal Longin Electrical 11 26-01-2005 00:47
Victor 884 Kevin Ray General Forum 25 28-01-2003 15:02
victor 883/884 Brett W Technical Discussion 21 08-01-2003 20:36
Victor 884 Gary Bonner Technical Discussion 4 14-01-2002 08:10
