Go to Post [how to read the rules] Slowly, carefully, word by word, taking your time as if it was the last corndog of the summer. - Foster [more]
Unread 01-07-2007, 13:16
Devo1098 Devo1098 is offline
FRC #1098
Devo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really nice
oldish motor pinion
i have a dewalt motor, and i need specs of the pinion gear and torque curves,
the number on the side of the motor is 2 607 022 078 then below that + 290 11 20
the gear is 15 teeth, and clues or help needed!
the second motor i have is a rs-545sh, i can probally get the curves from banebots but i don't know about the pinion, the number on the motor can is T9071920, the gear has 14 teeth
Devo
Unread 01-07-2007, 13:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: oldish motor pinion
That first one is a Bosch motor, and it is a 0.7 Module gear. The only sources of 0.7 module gears in the US (that I know of) are SDP-SI (for plastic gears) and Pic-Design (long lead time) for metal gears.
Unread 01-07-2007, 14:17
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
Another alternative is to get somebody to burn one for you using wire EDM. Many EDM houses have programs that will create wire paths based on the gear specs. This is a pretty small job and it won't take long so it shouldn't be too expensive.
Christopher H Husmann, PE
"Who is John Galt?"
Fisher-Price 00968-9012 motor pinion Joe P Motors 3 03-04-2007 19:31
Converting the Bosch Metric Pinion into an English- Specification Pinion evolution Motors 3 28-08-2004 16:30
Drill Motor pinion Justin Stiltner Technical Discussion 2 21-01-2004 02:43
BOSCH motor pinion pitch Matt Reiland Technical Discussion 2 10-01-2003 09:26
Chiaphua Motor Pinion Gear Joe P Inventor 0 27-02-2002 15:48
