Go to Post You mean i can do something with the Kinect other than put large dents in wall with a robot? Rad.. - rachelholladay [more]
Unread 03-07-2007, 11:00
ThorDiantral ThorDiantral is offline
Short Fat Kid
AKA: J Dizzle
FRC #0595 (Robodawgs)
ThorDiantral is an unknown quantity at this point
Send a message via AIM to ThorDiantral
Looking for a supplier of Keyed Aluminum Shaft
Our team has been experimenting with arm designs and different ways to power them. Our current supplies, as far as a spocket set up goes, are completely iron. We've ordered aluminum sprockets, which cut the weight by50%, if not more. We're were wondering if we could use aluminum for the shafts. We've looked around quite a bit but can only find keyed shafts made of steel or an alloy of steel. We were wondering if anyone had a supplier or maybe knew of a different material , similar weight-wise, to aluminum. Any help would be useful.
Here is what we're looking for:
3/4" in diameter
3/16" key width
1/16" key depth
Thanks again,
545
Unread 03-07-2007, 11:09
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Re: Looking for a supplier of Keyed Aluminum Shaft
mcmaster-carr
mcmaster.com
Part # 1570K63
it also comes in shorter lengths
the depth is 1/32 different from the specs you posted, but that shouldn't matter for most applications
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 03-07-2007, 11:22
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Without seeing your basic design it's hard to know if this will help, but you migth be able to redesign it so that the sprocket attatches to the arm instead of the shaft (with a bearing between the two)....this might allow you to use a smaller shaft and not have to worry about keying it.
igus parts are really nice for arm pivots, although it takes some effort to figure out how make it all work. And possibly a lathe.
Unread 03-07-2007, 14:29
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
Team Role: Leadership
Rookie Year: 2000
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Post Re: Looking for a supplier of Keyed Aluminum Shaft
Misumi is a good place to find precision shafts and such. We use them a lot when we want to buy commercial off-the-shelf assemblies. You can get pretty much any type of shaft, bearing, or gear you could want.
Website here: http://www.misumiusa.com/
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 03-07-2007, 18:05
Carmine Rizzo Carmine Rizzo is offline
FRC #0075 (RoboRaiders)
Rookie Year: 1999
Carmine Rizzo is just really niceCarmine Rizzo is just really niceCarmine Rizzo is just really niceCarmine Rizzo is just really nice
Team #75 has been using Aluminum Sprockets and Shafts for many years. The type of Aluminum you specify is important. The application loads, forces and process will dictate the use of these materials. We have also used Titanium (6Al-4V (a/k/a Grade 5)) for shafting. The Aluminum we have used in the past has been 7075 for shafting and sprockets. The Aluminum has held up in most applications but a Slight press fit helps the application. We have also used Lock-tite to help in the assembly. If you are using a set screws or screws during assembly, with aluminum you should size the screws for Course thread pitches. I would also double up on the set screws, as then tend to loosen during use and eventually fall out. Getting back to your original question. These are specialized materials and you would probably have to get a machine shop to fabricate the keyways in the shafts. I’m sure any local shop would help out if you ask.
Place to order Material.
http://www.onlinemetals.com/
Carmine
Team 75 Mentor
Unread 03-07-2007, 19:20
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Misumi is a very good company. We also ordered Aluminum shaft from them this season, along with a bunch of other materials/parts. We were very happy with the products.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Looking for a keyed sprocket Jeff Waegelin Technical Discussion 16 30-01-2007 14:45
Matching a Gear to Keyed Shaft of DC Motor Spindle Motors 9 22-05-2005 20:23
5/8 keyed shaft trouble dddriveman Technical Discussion 14 18-05-2004 09:49
supplier for 5/8" shaft david.clark Kit & Additional Hardware 2 17-01-2004 18:13
Looking for aluminum wire archiver 2000 5 23-06-2002 23:48
