Go to Post I'm sure they liked the size and power output but disliked when they were on fire. - notmattlythgoe [more]
Unread 20-07-2007, 23:09
TimK TimK is offline
TimK is an unknown quantity at this point
Cmucam2+ Problems
Hi,
I purchased the CMUcam2+ in order to have the camera integrated in to a robot. When I power the camera using a 8.5 DC adapter, 350mA, the Power LED turns green and the SX52 processor on the camera's PCB gets so hot that you can't touch it(about 50 + degrees C)! My question is; is this normal?( I am assuming not) How can I fix this? I tried a 6 V power supply made of 1.5 V alcaline batteries and the SX52 still heats up!
1.I tied to set up communication with a PC by building a RS232 Level Converter with no luck.
2. Tilt/PAn auto mode does not work as outlined in the CMUcam2 manual.
3. None of the status LED's light up
CMUcam2 LabVIEW GUI problems StevenB Programming 1 21-01-2006 03:08
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Problems tracking with CMUCam2 in LabVIEW PhilBot LabView and Data Acquisition 5 17-01-2006 20:42
CMUCAM2 Recognition Problems muy dificil Programming 0 04-11-2005 11:32
CMUCam2 Vision Sensor Testing/Problems cbolin Programming 18 02-02-2005 18:03
