Go to Post Robots can be fixed, glory is forever - Brandon Holley [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 25-07-2007, 21:05
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Using Inventor for Arm torque calcs
Rather than estimation and integrating the weight of an arm + whatever it is lifting to calculate what kind of gearing/motor to use... is there a feature in inventor that can give you those numbers? It'd be nice to simply put whatever object that needs to be lifted (with accurate weight) at the end of the arm and see the actual numbers.
Using auto cad for the autodesk inventor competition [527]phil Inventor 7 18-01-2006 10:41
Using Inventor without Excel jdiwnab Inventor 4 14-12-2005 14:28
What kind of material will you be using for your arm/forklift? Atman Technical Discussion 35 31-01-2005 15:28
Problems with transmission using Inventor 8 Drew Hopman Inventor 4 10-01-2005 19:07
Clac. of Motor Torque Requirement for a bot drive archiver 2001 2 23-06-2002 23:29
