pic: Custom Machined Aluminum #25 Sprocket
Re: pic: Custom Machined Aluminum #25 Sprocket
Looks nice... These were in the drive I assume.
How long did it take to machine? How many set ups? (I'm assuming one on a CNC mill and one on a waterjet/lathe) do you know if the amount of weight saved (how much did it save?) was worth the extra time? |
Machining time was a little over an hour. 1 setup on the mill. Holes were tapped by hand afterwards. Slight tooth chamfer was done on the lathe afterwards.
Was it worth the time? Probably not, but they do look nice. |
Did you cut the teeth on the mill as well?
If so, what diamater cutter was used? |
Are those radiused areas in the center contoured?
Or do they just happen to be the same radius as a ball endmill you ran through there? Those are some sick sprockets. |
Woah. I don't think I've seen a sprocket that sexy since one of 233's huge pink ones.... This one is just elegant though! It makes me wish more and more that my team had a CNC...
Nice job! |
two words: SICK NASTY!
190 had AL drive sprockets (31 teeth, I don't know why they HAD to be 31 teeth), but they were no where near as sexy as that beast...nicely done |
Pretty snazzy!
Form does indeed follow functionality. ![]() |
What feedrate did you cut it at? That's a lot of material to remove just to avoid using spacers. But it does look quite nice.
#10
TyTown those sprockets are absolutely ridiculous, I want one
#11
as Borat would say "Very Nice"
| pic: MVRT1115 small machined parts | Ashwin | Extra Discussion | 5 | 23-02-2007 13:22 |
| pic: 254/968 Machined Parts | Cory | Robot Showcase | 11 | 12-02-2007 07:42 |
| pic: Team 1538's Machined Parts (C) | Jon Jack | Extra Discussion | 19 | 23-01-2007 02:06 |
| pic: 1538's Machined Parts (B) | Jon Jack | Extra Discussion | 2 | 21-01-2007 20:31 |
| #25 Aluminum Sprocket Source | Don Wright | Kit & Additional Hardware | 1 | 26-01-2005 13:41 |
