Go to Post And please, never scorn a team that makes something outrageous, like a 4 speed 6 motor transmission. - Veselin Kolev [more]
Unread 12-08-2007, 09:41
Spencer E.'s Avatar
Spencer E. Spencer E. is offline
Android junkie
FRC #1305 (NNSRI Ice3 (cubed))
Spencer E. has a spectacular aura aboutSpencer E. has a spectacular aura about
Send a message via MSN to Spencer E.
Talking New autonomous method in the works :D
Hey everyone! Some of you may have seen my previous posts about the potential of using a GBA as a serial communication device with the RC (http://www.chiefdelphi.com/forums/sh...d.php?t=56703). Well, I've just started the programming for both the GBA and RC programs and I'm hoping to have it fully working and functional by kick-off at the latest. Where I am stuck as of now is finding the funds for a Flash cartridge and parts to make the serial cable to go from the GBA to the RC.
The GBA program will have a working GUI and will be able to show the path of the robot on screen as you create the autonomous. How it will work is: the user will create a set of commands for the robot to do (ie. go a certain distance at a certain speed, turn a certain amount of degrees) on the GBA. Once they have done this, the RC will be set to wait for the beginning of the GBA transmission. As the RC receives each command it will make sure it has not missed any data and store the command in the EEPROM, then will relay a message back to the GBA asking for more information. Then voila! The autonomous is stored within the EEPROM.
Now, when autonomous begins the RC will read the commands from the EEPROM and execute the corresponding functions relating to the commands.
Any constructive criticism is welcome
New alliance selection method Bharat Nain Rules/Strategy 5 08-01-2006 22:16
New compression method Aalfabob Programming 99 03-10-2004 16:21
Autonomous Method Astronouth7303 Programming 3 25-02-2004 17:14
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
A New Method of Handling Nationals archiver 2001 9 24-06-2002 03:30
