Water proofing a Project
First of all as an idea how about an off topic technical forum for random mechanical, electrical, and programming questions that have no relation to FIRST? LIke the Chit chat but pure technical threads.
Ok, my main point. The other night I was at a friends house when she was showing me the lighting in her pool so I had the idea of making little floating lighting elements. The problem is that I would like to make them totally submersible so you could just leave them in the rain and not worry about how you get them out. The problem is I want to be able to make them so that I can change the batteries in them. So it would need to be some type of box. I was thinking of maybe of just casting the actual control board or whatever I choose to do for the control (whether it be a micro controller or what) is some sort of non conductive resin but then I still have to worry about the battery. Then I though of using vacuum bags, but they are pricey, then I thought of the big sheets of laminate for text books but then how do I seal the box and what if water gets under the laminate? Do you guys have any ideas? -John |
Re: Water proofing a Project
it is actually alot easier then you think. All you need is well placed gaskets and o-rings. There is a really good chapter in the machinists handbook on them, but the basic gist of things is you have 2 surfaces (like panel that comes off, and the plate it attaches to) and you cut a small groove (dimensioned to the size of the o-ring). When you put the 2 parts together it squishes the o-ring and creates a water proof seal. If you open most any electronics that are water resistant or proof you will see one of these. A good cheap example if you wanted to find one is a shower radio.
there is a clear plastic food storage container you can get at Walmart (?) that has a rubber o ring in the lid, and latches to hold the lid on, brand name LOCK & LOCK maybe it would do the job.
(after smearing vaseline on the o-ring) |
I forgot all about "tupper ware" type containers. I should just try buying some glad wear and putting a huge bead of silicone in the crease on the top if it isnt water proof right away.
-John |
Last edited by GBIT : 17-08-2007 at 07:27. Reason: i figured the product # would help. |
Team 842 came up with a rather unique solution for their first entry in the underwater robotics championship. http://www.wired.com/wired/archive/13.04/robot.html
A good reference we use at work for o-ring seals is the Parker O-Ring Handbook. The Parker O-Ring Handbook goes over just about everything you would ever want to know about o-rings. Everything from materials and handling, applications, lubrication, groove sizes for various types of seals, o-ring profiles, etc, etc, etc.
#10
Those "lock and lock"containers are really nice! You could also investigate various PVC pipe fittings and cobble something together. Most of the plumbing stuff at my house is waterproof, LOL!
#11
If you want something a little tougher than tupperware or whatever people are suggesting, get a small ammunition can from eBay or such, then build the light into that (anywhere on the box is fine really, so long as it can still latch shut). Then waterproof the light and the hole it's sitting in and you're good to go with a military ammo-can light-thing that you can still open up and work on and is perfectly waterproof.
#12
| [ECDU]:water | Michael Leicht | FIRST-related Organizations | 4 | 15-08-2004 19:13 |
| Water cooling? | kc8nod | Motors | 12 | 08-02-2003 10:17 |
| Water fights? | archiver | 2001 | 2 | 24-06-2002 03:07 |
| FIRST water | Jon K. | General Forum | 22 | 08-05-2002 19:50 |
