Go to Post Water game. - dlavery [more]
Unread 14-09-2007, 21:33
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Team Role: Coach
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Beverage chillin' machine.
Ok, heres the deal. I want to buy a 5/10 gallon water cooler. I don't want to ever buy ice again. So heres the challenge. Adapt a cooler to be able to plug into an outlet or ALSO be able to be powered by batteries for when im camping to keep the water cold.
I thought about a PC water coolign system but i talked to a friend and said that will not work. so i come to the CD community. what shall i do?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 15-09-2007, 11:50
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Beverage chillin' machine.
For power, set it up to operate on either 12 volts (then use a 110 power supply) or 110 volts (then use a 12 volt to 110 volt inverter).
For coolness, you can use a classical refrigeration system (but heavy, relatively fragile) of Peltier devices (limited capacity for cooling, especially freezing). Peltiers need heat sinks, cooling fans and have a limited temperature differential, possibly requiring stacked units for the temperatures you want.
Real water ice has a lot going for it. 10 pounds of it can take 288 ounces of liquid from 90 F down to 34 F in about an hour, and hold it there (in a commercial ice chest) for easily more than a day. The energy required to change phase from solid to liquid is considerable, so you are storing quite a bit of energy in that solid water - more than you might get out of a comparable weight of battery. The byproduct - water - is generally environmentally compatible.
Don
Unread 15-09-2007, 13:02
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Check out the Cooper Cooler.
I'm not sure about batteries though.
pic: me chillin in chicago its da PAT!!! Chit-Chat 3 22-02-2007 11:26
One machine? mzitz2k General Forum 19 03-03-2004 17:42
Brazilian Machine team_383 General Forum 1 22-01-2004 10:33
Choosing a machine shop (Re: How important is a machine shop archiver 2001 9 24-06-2002 04:20
The only thing I'll miss from nationals: Frozen Carbonated Beverage asher Chit-Chat 22 30-04-2002 18:46
