Error in code light on, trouble finding error
Hey guys, finally got code to compile (I really hate MPLAB now), and got it to download to the controller, but the OI has the code error, no valid data/radio (blinking red), Program state (blinking orange), and radio modem (blinking red) lights on, and the RC mode light is off. I've been looking through the code, and have no idea whats going on.
User Routine- Code:
* FILE NAME: user_routines.c <FRC VERSION>
* DESCRIPTION:
* This file contains the default mappings of inputs
* (like switches, joysticks, and buttons) to outputs on the RC.
* USAGE:
* You can either modify this file to fit your needs, or remove it from your
* project and replace it with a modified copy.
#include <stdio.h>
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "user_routines.h"
#include "serial_ports.h"
#include "pwm.h"
#include "camera.h"
#include "camera_menu.h"
#include "tracking.h"
#include "tracking_menu.h"
#include "eeprom.h"
#include "terminal.h"
extern unsigned char aBreakerWasTripped;
int intMax(int x, int y)
int max = x;
if(y > max)
max = y;
return max;
int intABS(int i)
if (i < 0)
return -i;
else
return i;
rom const int ctbl[255] = {-127, -124.654754, -122.3407176, -120.0583477,
-117.8073909, -115.5875939, -113.3987034, -111.2404659,
-109.1126283, -107.0149371, -104.947139, -102.9089807,
-100.9002089, -98.92057018, -96.96981128, -95.04767885,
-93.15391954, -91.28828005, -89.45050702, -87.64034713,
-85.85754704, -84.10185344, -82.37301297, -80.67077232,
-78.99487816, -77.34507714, -75.72111594, -74.12274122,
-72.54969966, -71.00173793, -69.47860269, -67.9800406,
-66.50579835, -65.05562259, -63.62926, -62.22645725,
-60.84696099, -59.49051791, -58.15687466, -56.84577793,
-55.55697437, -54.29021066, -53.04523346, -51.82178944,
-50.61962527, -49.43848762, -48.27812316, -47.13827855,
-46.01870047, -44.91913557, -43.83933055, -42.77903204,
-41.73798674, -40.71594131, -39.71264241, -38.72783671,
-37.76127088, -36.81269159, -35.88184552, -34.96847932,
-34.07233966, -33.19317322, -32.33072666, -31.48474665,
-30.65497986, -29.84117296, -29.04307261, -28.26042549,
-27.49297827, -26.7404776, -26.00267016, -25.27930263,
-24.57012165, -23.87487392, -23.19330609, -22.52516483,
-21.87019681, -21.2281487, -20.59876716, -19.98179888,
-19.37699051, -18.78408872, -18.20284018, -17.63299156,
-17.07428953, -16.52648076, -15.98931191, -15.46252965,
-14.94588066, -14.4391116, -13.94196914, -13.45419994,
-12.97555068, -12.50576802, -12.04459864, -11.5917892,
-11.14708637, -10.71023681, -10.28098721, -9.859084213,
-9.444274504, -9.036304746, -8.634921609, -8.239871761,
-7.85090187, -7.467758605, -7.090188633, -6.717938625,
-6.350755247, -5.988385169, -5.630575058, -5.277071584,
-4.927621415, -4.581971219, -4.239867665, -3.901057421,
-3.565287155, -3.232303537, -2.901853234, -2.573682915,
-2.247539249, -1.923168903, -1.600318547, -1.278734848,
-0.958164476, -0.638354098, -0.319050383, 0,
0.319050383, 0.638354098, 0.958164476, 1.278734848,
1.600318547, 1.923168903, 2.247539249, 2.573682915,
2.901853234, 3.232303537, 3.565287155, 3.901057421,
4.239867665, 4.581971219, 4.927621415, 5.277071584,
5.630575058, 5.988385169, 6.350755247, 6.717938625,
7.090188633, 7.467758605, 7.85090187, 8.239871761,
8.634921609, 9.036304746, 9.444274504, 9.859084213,
10.28098721, 10.71023681, 11.14708637, 11.5917892,
12.04459864, 12.50576802, 12.97555068, 13.45419994,
13.94196914, 14.4391116, 14.94588066, 15.46252965,
15.98931191, 16.52648076, 17.07428953, 17.63299156,
18.20284018, 18.78408872, 19.37699051, 19.98179888,
20.59876716, 21.2281487, 21.87019681, 22.52516483,
23.19330609, 23.87487392, 24.57012165, 25.27930263,
26.00267016, 26.7404776, 27.49297827, 28.26042549,
29.04307261, 29.84117296, 30.65497986, 31.48474665,
32.33072666, 33.19317322, 34.07233966, 34.96847932,
35.88184552, 36.81269159, 37.76127088, 38.72783671,
39.71264241, 40.71594131, 41.73798674, 42.77903204,
43.83933055, 44.91913557, 46.01870047, 47.13827855,
48.27812316, 49.43848762, 50.61962527, 51.82178944,
53.04523346, 54.29021066, 55.55697437, 56.84577793,
58.15687466, 59.49051791, 60.84696099, 62.22645725,
63.62926, 65.05562259, 66.50579835, 67.9800406,
69.47860269, 71.00173793, 72.54969966, 74.12274122,
75.72111594, 77.34507714, 78.99487816, 80.67077232,
82.37301297, 84.10185344, 85.85754704, 87.64034713,
89.45050702, 91.28828005, 93.15391954, 95.04767885,
96.96981128, 98.92057018, 100.9002089, 102.9089807,
104.947139, 107.0149371, 109.1126283, 111.2404659,
113.3987034, 115.5875939, 117.8073909, 120.0583477,
122.3407176, 124.654754, 127};
int joysticklimit(int inp)
if(inp < 127)
inp += 1;
return inp;
else if (inp > 127)
inp -= 1;
return inp;
else
return inp;
int count = 0;
int nestedcount = 0;
static int oldcount = 0;
int countvert = 0;
static int oldcountvert = 0;
int countvert2 = 0;
static int oldcountvert2 = 0;
int count3 = 0;
static int oldcount3 = 0;
int rotationfw = 0;
int rotationrv = 0;
int groundlevel = 0;
int toplevel = 0;
/*** DEFINE USER VARIABLES AND INITIALIZE THEM HERE ***/
/* EXAMPLES: (see MPLAB C18 User's Guide, p.9 for all types)
unsigned char wheel_revolutions = 0; (can vary from 0 to 255)
unsigned int delay_count = 7; (can vary from 0 to 65,535)
int angle_deviation = 142; (can vary from -32,768 to 32,767)
unsigned long very_big_counter = 0; (can vary from 0 to 4,294,967,295)
* FUNCTION NAME: Limit_Switch_Max
* PURPOSE: Sets a PWM value to neutral (127) if it exceeds 127 and the
* limit switch is on.
* CALLED FROM: this file
* ARGUMENTS:
* Argument Type IO Description
* switch_state unsigned char I limit switch state
* *input_value pointer O points to PWM byte value to be limited
* RETURNS: void
void Limit_Switch_Max(unsigned char switch_state, unsigned char *input_value)
if (switch_state == CLOSED)
if(*input_value > 127)
*input_value = 127;
* FUNCTION NAME: Limit_Switch_Min
* PURPOSE: Sets a PWM value to neutral (127) if it's less than 127 and the
* ARGUMENTS:
* RETURNS: void
void Limit_Switch_Min(unsigned char switch_state, unsigned char *input_value)
if(*input_value < 127)
*input_value = 127;
* FUNCTION NAME: Limit_Mix
* PURPOSE: Limits the mixed value for one joystick drive.
* CALLED FROM: Default_Routine, this file
* ARGUMENTS:
* intermediate_value int I
* RETURNS: unsigned char
unsigned char Limit_Mix (int intermediate_value)
static int limited_value;
if (intermediate_value < 2000)
limited_value = 2000;
else if (intermediate_value > 2254)
limited_value = 2254;
else
limited_value = intermediate_value;
return (unsigned char) (limited_value - 2000);
* FUNCTION NAME: User_Initialization
* PURPOSE: This routine is called first (and only once) in the Main function.
* You may modify and add to this function.
* CALLED FROM: main.c
* ARGUMENTS: none
* RETURNS: void
void User_Initialization (void)
Set_Number_of_Analog_Channels(SIXTEEN_ANALOG); /* DO NOT CHANGE! */
/* FIRST: Set up the I/O pins you want to use as digital INPUTS. */
digital_io_01 = digital_io_02 = digital_io_03 = digital_io_04 = INPUT;
relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
/* FOURTH: Set your initial PWM values. Neutral is 127. */
pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
/* FIFTH: Set your PWM output types for PWM OUTPUTS 13-16.
/* Choose from these parameters for PWM 13-16 respectively: */
/* IFI_PWM - Standard IFI PWM output generated with Generate_Pwms(...) */
/* USER_CCP - User can use PWM pin as digital I/O or CCP pin. */
// Setup_PWM_Output_Type(IFI_PWM,IFI_PWM,IFI_PWM,IFI_PWM);
// changed so PWM() can control PWM outputs 13 through 16
Setup_PWM_Output_Type(USER_CCP,USER_CCP,USER_CCP,USER_CCP);
Example: The following would generate a 40KHz PWM with a 50% duty cycle on the CCP2 pin:
CCP2CON = 0x3C;
PR2 = 0xF9;
CCPR2L = 0x7F;
T2CON = 0;
T2CONbits.TMR2ON = 1;
Setup_PWM_Output_Type(USER_CCP,IFI_PWM,IFI_PWM,IFI_PWM);
/* Add any other initialization code here. */
// initialize the CCP PWM hardware
Initialize_PWM();
// initialize the serial ports
Init_Serial_Port_One();
Init_Serial_Port_Two();
// make sure printf() output goes to the proper port
#ifdef TERMINAL_SERIAL_PORT_1
stdout_serial_port = SERIAL_PORT_ONE;
#endif
#ifdef TERMINAL_SERIAL_PORT_2
stdout_serial_port = SERIAL_PORT_TWO;
#endif
Putdata(&txdata); /* DO NOT CHANGE! */
User_Proc_Is_Ready(); /* DO NOT CHANGE! - last line of User_Initialization */
* FUNCTION NAME: Process_Data_From_Master_uP
* PURPOSE: Executes every 26.2ms when it gets new data from the master
* microprocessor.
* ARGUMENTS: none
* RETURNS: void
void Process_Data_From_Master_uP(void)
static unsigned char i;
Getdata(&rxdata); /* Get fresh data from the master microprocessor. */
Default_Routine(); /* Optional. See below. */
/* Add your own code here. (a printf will not be displayed when connected to the breaker panel unless a Y cable is used) */
printf("Port1 Y %3d, X %3d, Fire %d, Top %d\r",pwm01,pwm05,p1_sw_trig,p1_sw_top); /* printf EXAMPLE */
/* Example code to check if a breaker was ever tripped. */
* FUNCTION NAME: Default_Routine
* PURPOSE: Performs the default mappings of inputs to outputs for the
* Robot Controller.
* CALLED FROM: this file, Process_Data_From_Master_uP routine
* ARGUMENTS: none
* RETURNS: void
void Default_Routine(void)
signed double wL, wR, velocity, rotation, wMax;
signed int difference, difference2, difference3, difference4;
signed int prepwm01, prepwm02;
static char pwm01_1, pwm02_1;
/*velocity = (p1_y - 127);
rotation = (p1_x - 127); */
if (rc_dig_in01 == 1) { //If tank pressure is 120... (Jeff didn't know whether the switch gave a 1 or 0 at 120psi)
relay2_fwd = 0;
relay2_rev = 0;
else {
relay2_fwd =1;
relay2_rev = 0;
velocity = deadband(p1_y,127,15);
rotation = deadband(p1_x,127,15);
velocity = ctbl[joysticklimit(p1_y)];
rotation = ctbl[joysticklimit(p1_x)];
wL = velocity - rotation;
wR = velocity + rotation;
wMax = intMax(127, intABS(wL));
wMax = intMax(wMax, intABS(wR));
/*Below check if the wheel output thingamajigger is valid or not (less than 127, great than -127).
If it isn't, it will go on and check the next wheel output, and if it's all good, it'll write it to prepwms
wL = (wL * 127 / wMax);
if (-127 > wL || wL > 127)
printf("Received an unexpected number [wL] /n");
else
wR = (wR * 127 / wMax);
if (-127 > wR || wR > 127)
printf("Received an unexpected number [wR] /n");
else
prepwm01 = wL + 127;
prepwm02 = 127 - wR;
// looking at the wheels counter clockwise is postive
// 7 is too little,
if ((prepwm01 > 127) && (prepwm01 < 180)) {
prepwm01 = prepwm01 + 12;
if ((prepwm02 > 127) && (prepwm02 < 180)) {
prepwm02 = prepwm02 + 12;
pwm01 = prepwm01;
pwm02 = prepwm02;
/*if (((intABS((char)pwm01 - pwm01_1)) > 0 ) || ((intABS((char)pwm02 - pwm02_1)) > 0 ) || ((intABS((char)pwm03 - pwm03_1)) > 0 ) || ((intABS((char)pwm04 - pwm04_1)) > 0 )) {
printf(" pwm01: %d , pwm02: %d \r", pwm01, pwm02);
printf(" Port 1 Y: %d , Port 1 X: %d , Port 2 X: %d \r", p1_y, p1_x, p2_x);
pwm01_1 = intABS(pwm01 - 127);
pwm02_1 = intABS(pwm02 - 127);
/*---------- Buttons to Relays----------------------------------------------
* This default code maps the joystick buttons to specific relay outputs.
relay1_fwd = p1_sw_trig;
relay1_rev = p1_sw_top; //Will kick if trigger is pulled, retract if top button is pushed. No button = no kicker action.
/*---------- ROBOT FEEDBACK LEDs------------------------------------------------
* This section drives the "ROBOT FEEDBACK" lights on the Operator Interface.
* The lights are green for joystick forward and red for joystick reverse.
* Both red and green are on when the joystick is centered. Use the
* trim tabs on the joystick to adjust the center.
* These may be changed for any use that the user desires.
if (user_display_mode == 0) /* User Mode is Off */
{ /* Check position of Port 1 Joystick */
if (p1_y >= 0 && p1_y <= 56)
{ /* Joystick is in full reverse position */
Pwm1_green = 0; /* Turn PWM1 green LED - OFF */
Pwm1_red = 1; /* Turn PWM1 red LED - ON */
else if (p1_y >= 125 && p1_y <= 129)
{ /* Joystick is in neutral position */
Pwm1_green = 1; /* Turn PWM1 green LED - ON */
else if (p1_y >= 216 && p1_y <= 255)
{ /* Joystick is in full forward position*/
Pwm1_red = 0; /* Turn PWM1 red LED - OFF */
else
{ /* In either forward or reverse position */
} /*END Check position of Port 1 Joystick
/* Check position of Port 2 Y Joystick
(or Port 1 X in Single Joystick Drive Mode) */
if (p2_y >= 0 && p2_y <= 56)
Pwm2_green = 0; /* Turn pwm2 green LED - OFF */
Pwm2_red = 1; /* Turn pwm2 red LED - ON */
else if (p2_y >= 125 && p2_y <= 129)
Pwm2_green = 1; /* Turn PWM2 green LED - ON */
Pwm2_red = 1; /* Turn PWM2 red LED - ON */
else if (p2_y >= 216 && p2_y <= 255)
{ /* Joystick is in full forward position */
Pwm2_red = 0; /* Turn PWM2 red LED - OFF */
else
Pwm2_green = 0; /* Turn PWM2 green LED - OFF */
} /* END Check position of Port 2 Joystick */
/* This drives the Relay 1 and Relay 2 "Robot Feedback" lights on the OI. */
Relay1_green = relay1_fwd; /* LED is ON when Relay 1 is FWD */
Relay1_red = relay1_rev; /* LED is ON when Relay 1 is REV */
Relay2_green = relay2_fwd; /* LED is ON when Relay 2 is FWD */
Relay2_red = relay2_rev; /* LED is ON when Relay 2 is REV */
Switch1_LED = !(int)rc_dig_in01;
Switch2_LED = !(int)rc_dig_in02;
Switch3_LED = !(int)rc_dig_in03;
} /* (user_display_mode = 0) (User Mode is Off) */
else /* User Mode is On - displays data in OI 4-digit display*/
User_Mode_byte = backup_voltage*10; /* so that decimal doesn't get truncated. */
Re: Error in code light on, trouble finding error
Try loading the default code and then loading your code. A lot of times weird problems like this aren't problems in the code but weird transmission errors or something.
The file looks okay at first glance -- no obvious infinite loops or wild pointers.
The first thing I'd check is that you're compiling the project for the proper version of the RC. The 2004 and 2005 systems use a different user PIC than the 2006 and 2007 systems do. What year's RC are you using, and what year's default code did you start with? The newer default code includes a file with instructions for making changes so it can be used with the older hardware. |
Make sure your radios are connected properly, and download the default code.
I can sympathize with you on MPLAB, it can be a pain to find the run-time errors.
Please remember that most causes of the red light of death are caused by not refreshing within the time limits of the processor, or every 26.3 ms. That ROM array you are initializing at the start looks pretty big. Do you really need that level of precision? Each character will probably eat up 2 bytes of RAM. Including the camera code and other functions is probably pushing you to the limits of the processors RAM during run time. My 2cents. |
Tanis, you're only putting values between -127 and 127 in the array. That will fit in a signed char if you do want to cut the array's size in half. Quote:
But I didn't notice the reference to camera and tracking code before. The serial port support that goes along with them requires specific changes to the interrupt service routine. Failing to handle interrupts properly is another way to cause the code error light to come on. Tanis, are you actually using the camera? If so, make sure you've done the appropriate things to user_routines_fast.c as called out in the camera code documentation, and don't forget to call the camera tracking function in the main loop, probably from Default_Routine(). If not, don't #include the unnecessary files. |
Using the C18 compiler, 2007 RC, and an edited version of the default master code currently available off the IFI site.
I decided to get rid of the table, it was just a test (one of our mentors suggested it), and wouldn't have made much of a difference. We've tried reloading the code multiple times (also have used the default code a few times), and our code doesn't work. The default code works fine. We are not using the camera, so I got rid of that too. |
Does the code compile?
I mean, were you able to transfer it through IFI_Loader (although the code didn't work on the robot)? |
What is the name of the file you are trying to download to the RC?
#10
Yes, it compiles, and downloads to the RC.
The file is KickerCode.hex. |
#11
We've been working on it a bit more, the code we've been working on still doesn't work, and were currently trying to start from scratch. We got to about where we were before and it still wont work... suggestions?
#12
I can't offer any more suggestions without seeing your code. When you say "start from scratch", what exactly is the "scratch"? Specifically, are you taking the 2007 non-camera default code as a base, or are you beginning with something else? What files are you modifying?
#13
Plain, non camera code.
Editing User routines, and possibly ifi_aliases.h, depending on if we get our control box built. Going to add in all the header files in the original code, except tracking.h, tracking_menu.h, camera_menu.h, and camera.h. |
| Coder Error Light | paulcd2000 | Programming | 7 | 10-02-2007 15:52 |
| 180:Error: syntax error help! | seanl | Programming | 8 | 04-02-2007 11:31 |
| GTS Code Error (the red light of doom!) | Denz | Programming | 9 | 07-04-2006 17:39 |
| stupid Array error: Error [1300] stack frame too l | Validius | Programming | 7 | 27-01-2006 10:53 |
| C++ Code Error? | Adam Shapiro | Programming | 9 | 20-01-2003 13:24 |
