Go to Post If there's one thing I've learned, it's that the robot is never truly finished. - Joseph Smith [more]
Unread 15-10-2007, 23:28
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
OI digital inputs and Var res switches.
The switches in a PS2 controller are variable resistance. A lite touch gives about 5000 ohms and a hard press gives about 100 ohms. Will 5000 ohms pull the OI digital inputs low? Our team wants to use a PS2 controller and we don't want to go down the pic interface shown in the white paper. CTS makes 100k joysticks that are a direct replacement for the ones found in a cheap 5$ Radio Shack PS2 controller. If the variable resistance switches will work, then this is an easy hack. If anybody is interested these joysticks from digi key fit perfectly in allot of PS2 controllers.
http://www.ctscorp.com/components/Datasheets/252.pdf
Unread 16-10-2007, 13:17
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: OI digital inputs and Var res switches.
If they won't pull the inputs low... why now use a PSX/PSone controller?
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Question about digital inputs and outputs Torboticsmember Electrical 2 12-02-2007 22:51
Digital inputs in autonomous mode? Calvin Programming 8 18-02-2006 13:16
How to access other Digital inputs on OI? DougHogg Electrical 2 12-03-2003 13:57
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
