Go to Post I hope we as a team can learn the value of doing less but doing it incredibly well. - Rob Stehlik [more]
Unread 16-10-2007, 13:43
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Rookie Year: 2007
Japper has a spectacular aura aboutJapper has a spectacular aura about
four wheel drive
Is there any MPLab C-18 sample code out there for a four wheel drive system which uses 4 wheels (each with their own seperate motor)?
Thanks in advance
Unread 16-10-2007, 14:56
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: four wheel drive
Unless you need to control the front and rear motor speed separately on each side, there's no difference in either programming or wiring between what you're doing and a standard tank drive system with two motors in tandem on each side.
If you do want individual control of each motor...why? And how do you plan to give the driver that control?
Unread 16-10-2007, 15:09
Billfred's Avatar
Billfred Billfred is offline
The only theory I can think of is that a team would want to attempt a mecanum drive with the ability to switch quickly to a traditional skid-steer arrangement for strategy reasons. The answer to your other question is a little hard for me to compute on the amount of sleep I had last night.
Unread 16-10-2007, 21:58
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
Team Role: Coach
Rookie Year: 2000
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
I am not good at programing but if you use a "y" cable you can use four PWM's from two out puts, Also their is not much Programing to add two out puts to your joystick control. Look over the the program and every thing is labled and you should be able copy and past what you need. Look at the manual for the out put labels for the inputs and outputs, If I can figure it out anybody can. Start at this web site http://www.ifirobotics.com/white-papers.shtml
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
Four Wheel Drive Using Standard Transmissions daviamp Technical Discussion 4 18-01-2006 20:03
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
Four wheel drive question haverfordfords General Forum 25 25-01-2005 23:24
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
