Go to Post You're not on your own, use your team members. They are the most valuable source of ideas that you have. - fr05ty27355 [more]
Unread 16-10-2007, 19:45
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Code To Make The Radio Work
I have a robot with a 2004 RC and IO, but they are not communicating. The IO radio is transmitting but the RC radio is only on standby. We did a master reset but did not solve or problems. I was wonder if there was code that controlled the radio? When I tethered the robot, it work perfectly well! This is something that I never seen. Please Help! Thank You!
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Make your CAM2 work great! pafwl General Forum 0 06-04-2007 22:12
CANT GET THE CANERA CODE TO WORK!!!! plz HELP!! its da PAT!!! Programming 3 18-02-2007 23:07
Steps to make cam work? magical hands Programming 7 31-01-2006 17:43
Getting the Camera and Default Code to Work nukem Programming 5 18-01-2006 11:48
How to Make MS joystick work/has anyone used it in past? andhesayz Control System 25 17-01-2005 10:34
