Running Multiple Robots with the old Radios
I'm sure this has been asked before, but I couldn't find anything so I figure I'll just ask.
Our team has a few older robots (2006 and 2005) that we are using for demonstration and driver training. We have been trying to get them to run simultaneously but have been having problems with the radio signals. They appear to conflict with each other. They run fine individually, but with both on they lose the signal every few seconds. I've tried changing the team numbers, channels, everything I could think of and nothing seems to work. So basically I'm wondering if it is even possible to run multiple robots (using the old radios) at the same time. Is there something you can do to keep the signals from interrupting each others? ![]() |
Re: Running Multiple Robots with the old Radios
Chris,
You said that you were using old radios but you didn't indicate which rd/oi combinations you were using. New hardware is not compatable with the older radios. You need to check on the IFI website for info. |
With the more recent OIs (2005, 2006 and 2007 versions) you need to set the leftmost team number switch before the channel select switches will do anything. That means you'll be using a team number greater than 2048. The document Jack pointed to gives the details. Older OIs (2004 and earlier) need the "practice" pin on the competition port connected to ground in order to enable the alternate radio channels. |
I was never sure if the channel ever changed seeing as the C# on the OI stayed the same. I will have to try the leftmost team number switch as I don't believe they are set that high. Thanks for the advice! ![]() |
| What do you do with your old robots? | sanddrag | General Forum | 32 | 28-04-2009 17:58 |
| NEED HELP RUNNING MULTIPLE FUNCTIONS AT SAME TIME!! | rushrtr3 | Programming | 1 | 12-02-2006 02:01 |
| What to do with old robots? | Bcahn836 | General Forum | 54 | 26-04-2005 10:19 |
| pic: Fun with Old Robots! | CD47-Bot | Extra Discussion | 17 | 10-05-2004 10:49 |
| What do you do with old robots? | Gui Cavalcanti | General Forum | 29 | 05-05-2002 01:05 |
