Go to Post ...okay, maybe I have a xkcd addiction - plnyyanks [more]
Unread 24-10-2007, 20:07
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Re: Programming Team Size, and do they all do?
Gdeaver, we hope to eliminate this problem by having twice / three times a week meetings between the build and programming leaders.
We will probably all be working on all code together, so that should hopefully make it easier to share, assuming it's well-commented. Which is a pretty big assumption
Unread 03-11-2007, 16:31
shawger shawger is offline
Programming Subteam Leader
FRC #1732 (Hilltopper Robotics)
shawger will become famous soon enough
I think with this many programmers you have some great options not available to many teams, but you will have to figure out how to be organized.
You should definately use a source code control system like subversion or CVS. That way, multiple people can work on different areas of the code at the same time, and then merge their changes together. With proper commenting on each commit, this could also help as a documentation tool.
You can also create branches in a source code control system. Maybe there are two or three different ways you could solve a problem. Why not create a new branch for each way, try them all out, and see which one works best?
Also make sure you keep documentation on the code as you write it. Last year, I wrote the code and wrote the documentation afterward. Given that I was really the only one doing the programming, it wasn't a big deal for me. However, it took awhile to do, and with many people working on the code, everybody will need to know how it all works.
All female team- students AND mentors Marie General Forum 22 15-02-2008 13:06
Team 862: Programming Collaboration and Help Forums GhostInTheShell Programming 1 10-11-2006 17:17
Programming Team Size coastertux Programming 33 12-01-2006 00:13
FAHA: When Some one thinks they know all. Ken Leung General Forum 9 16-02-2004 23:33
