Go to Post Use checklists. If it's good enough for NASA, it's good enough for FIRST. - Rick TYler [more]
Unread 22-10-2007, 18:59
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
Team Role: Coach
Rookie Year: 1996
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Operator Interface Troubleshooting
Ok so we are having some problems with our 2007 'bot. We had removed our scoring mechanism to leave us just with our drive-train and electronics board. When trying to power up and drive the 'bot, we don't get any control for any input. We downloaded the default camera bells and whistles, and for the life of me I can't get any thing to respond to a control. I inserted pwm1=p1_y; into the user_routines.c in the normal place and hooked it up to one of our cam servo's, and it won't do anything. We are able to download the hex file successfully and get all 5 green lights on the OI. We don't have our TTL chip anymore (need to buy one again from IFI) or the 7.2 V battery but as far as I know we should still be able to do something, like control a motor. I believe that driving a servo without the 7.2 V battery won't work, but we tried a lot of other configurations in the code, like made pwm13=p1_x; to make the left drive motor respond only to the x-axis and it won't do anything. We get all flashing orange lights on the victor's but the cables seem to be in all the way, we had to cut the plastic connector down to the right sizing before and they worked before fine, we are just having problems with the same setup now. Anybody have any ideas? Very annoying problem.
operator interface carbuff Rules/Strategy 1 18-02-2007 09:06
operator interface tml240 Electrical 5 10-02-2004 17:50
Operator Interface Heads Up Madison Robotics Education and Curriculum 6 11-12-2002 06:59
operator interface board archiver 2001 4 24-06-2002 00:33
