Go to Post your time is better spent in the stands, watching what the robots actually do, as opposed to listening to the builders talk about what they're [I]supposed[/I] to do. - sanddrag [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 24-10-2007, 16:48
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Rookie Year: 1998
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking Re: Hacked
DDNS:
http://www.EditDNS.net is another good dynamic DNS, it works with domains like abc.xyz
Where abc is the Second level domain and xyz is the top level domain.
Its free to use and alows control over the A, AAA, MX, NS, SRV, CNAME
More advanced features cost $6 for 6 months access to setup, but once set you don't need to pay after the 6 months unless you need to change a more advanced feature. I use the free service with my self hosted web sites and it works great.
Hosting:
The company I work with uses host rocket to host theirs and their customers sites on.
http://www.hostrocket.com/
They have 24/7 tech support (Actually called at 2am on Saturday)
Misc:
I haven't had much php or mySQL experience yet (I use SQL express and ASP.net 2.0), but would recomend making sure everything is up to date, and recheck all settings for any possible security holes.
I have two dual Xeon 2.6GHz HT (Device manager shows 4 CPUs) servers each with 1GB of Ram, striping Raid on Data Drives (SCSI LVD), 250GB SAN Storage for backups, VPN/Firewall router between servers and Internet
I used one of these servers to host the live web cast of PARC X.
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 25-10-2007, 00:40
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Re: Hacked
Just to prove that Jacob's suggestion works, I'm making this post on my university's Windows Server 2003 terminal server, connected over Remote Desktop to a Windows XP virtual machine, which is itself connected over Remote Desktop to a Windows 98 virtual machine. Both VMs are running locally on Windows Vista (no, I didn't nest those too). It all seems to work pretty well (if you can tolerate 8-bit colour).
Unread 25-10-2007, 11:59
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: Hacked
You can change the color settings. Open the RDC windows, click "Options", Click the "Display" tab, and change it.
Eric Haskins KC9JVH
Unread 24-10-2007, 06:32
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
Re: Hacked
I'm surprised that so far people have missed the obvious step of first looking at what you've got that you control before assuming that the problem is with the host (which it may well be, but, that shouldn't be the first thing to check for).
Questions you should ask yourself include:
What software do you have installed in your webspace? (check and make sure there aren't little temporary things installed just for testing that were never removed and never properly secured, this happens often)
Is it up to date? (this can especially be a problem if your team is using a CMS or old versions of phpBB2 or other forum software)
If what you've got is custom written, has it been checked over by someone knowledgable other than just the person who wrote it? If not, maybe it's time to audit it.
Assuming you have access to the web server access logs and error logs, read them carefully for the period of time before the last time you had problems. If the exploit is attacking something your team has control over, it's likely to appear strange and show up there. Be especially vigilant for things like phpShell and such which you don't recognize as being part of a normal type of request.
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
Unread 24-10-2007, 08:02
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
Rookie Year: 1999
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Re: Hacked
I have been using bravehost.com for close to 5 years now, and I have NEVER ran into something like this. It may cost a little more (I pay $4.99/mo with 30gig of space and 600gig of bandwidth) but I have had absolutely no problems with there service. If you ask me, there setup is the cleanest easiest to work with, and most secure setup that is out there. Check it out, I would definitely say that they are my favorite, because I also have a godaddy.com and hostmonster.com hosting account, but I am definitely gona switch them over, because I really was not impressed with there service. But seriously, that is ridiculous.
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 24-10-2007, 08:55
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Re: Hacked
another site that I admin was hacked in the same way fairly recently. They replaced my site with some stupid splash screen, with the fools handle, a Turkish flag and a scrolling banner stating how "uber" this guy/gal was.
After some digging, We found that this person was exploiting a weakness in phpbb we were using. After updating the software, we haven't had a problem. no matter what you do you will always have a problem with security if you use a popular piece of software.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 24-10-2007, 10:20
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Hacked
It appears that this site is very cleancut and is lacking 3rd party apps (less the Google Gadget app, but I doubt there is a security problem in that). I looked at the source code, and everything looks HTML and Javascript.
Then I found forum.punahourobotics.org
It appears that they have the latest version of Simple Machines.
But I got to thinking, doesn't Simple Machines use MySQL, and PHP? That must mean that there is a MySQL server running on box188.bluehost.com, and perhaps this is the security hole. Check your MySQL version and patches, make sure it's all up to date.
What's odd is that a hacker would put this much effort into splashing a robotics team's website. Seems like it would be a fairly low-target kind of domain to hit.
Jacob
Unread 24-10-2007, 11:39
wilsonmw04's Avatar
Coach
Team Role: Teacher
Rookie Year: 2007
Re: Hacked
What they do is troll the internet looking for large hosting systems. Most of their accounts are small and use PhP Or MySQL. They don't care how big or small the site is. They do it for kicks.
Why do folks spray paint builds? Because they have brains no bigger than your average canine...
pic: Hacked Google Camera #1 Alex698 Extra Discussion 7 12-03-2006 13:32
pic: Hacked Google Camera Picture #2 Alex698 Extra Discussion 8 12-03-2006 00:17
Our forum has been hacked Shlomi32 Website Design/Showcase 1 27-01-2006 01:19
Hacked! Denman Website Design/Showcase 19 18-07-2004 12:04
