Re: USB - Serial cable
ok. now it gives me the red led, but keeps on searching....
sorry for all the mass... |
We kept getting the problem you are having. We tried downloading the default camera.hex file that comes with the default code on Kevin Watson's page, and it worked. Then we used the default code from there on. I think the problem had something to do with a conflict between pwm01 and pwm02.
We had to start over with the default code. But first download the default code and immediately load the precompiled hex file to the controller without compiling anything, since the code is supposed to work with the camera immediately.
| USB To Serial | Devo1098 | Programming | 3 | 30-06-2007 19:51 |
| Gameport to Usb cable vrs. Usb Chicklet | haywirerobotics | Control System | 4 | 25-01-2007 19:03 |
| usb to serial cable | karinka13 | Technical Discussion | 4 | 10-02-2006 17:30 |
| USB-Serial Cable + Terminal | Spencer E. | Programming | 3 | 22-01-2006 12:16 |
| Serial Cable | Andrew Rudolph | Technical Discussion | 9 | 15-08-2002 22:09 |
