Go to Post Ahem......"where are the President's safety glasses???" - Travis Hoffman [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 03-11-2007, 15:58
Popper99 Popper99 is offline
None #1726
Popper99 is an unknown quantity at this point
Problem With Footsteps
I've made a robot using the basic biped skeleton and changed the structure a bit (5 fingers and 1 spine). I then used the select and link tool to assign the arms to the skeleton's arms, legs, etc. I now want to use footsteps but the option remains gray and unusable. It works with other bipeds but not this one. It also worked just fine when I had only assigned the arms to the skeleton. Maybe I accidentally pressed some key combination (There are green squares highlighting the ends of joints that just randomly appeared)? Any help would be appreciated
Unread 04-11-2007, 09:34
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: Problem With Footsteps
And hence further supports my theory that bipeds should not be used. They cause to much trouble than they are worth. I have no idea, I don't use the biped. I make my own rigs and then loop a walk cycle.
But if i had to guess, make sure you are selecting the root of the biped (that little diamond shaped thingy) And, make sure you are selecting the footsteps that you want him to walk on.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Problem with MPLAB dpick1055 Programming 5 21-01-2007 00:34
Problem with RoboEmu2? Calvin Programming 1 12-02-2005 11:27
YMTC: Should big sister follow in little brother's footsteps? Natchez You Make The Call 13 07-12-2004 15:56
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
Problem with OI / RC Jay Lundy Technical Discussion 2 29-03-2002 23:07
