Go to Post You know you've made it big when people assume every imperfection is genius! - araniaraniratul [more]
Unread 07-11-2007, 09:51
AdamC's Avatar
AdamC AdamC is offline
Lathemeister
AKA: Batman
FRC #0395 (2Train Robotics)
Team Role: Mechanical
AdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of light
Send a message via AIM to AdamC
To Shift or Not To Shift, That is the Question
I'd like to pose a question for all the fellow mechies out there. In terms of drive trains, is it worth it to go through the extra weight of shifters, or is it better to just stick with a solid gear ratio that finds a balance between power and speed. We tried shifters last year, and made a pretty solid and lightweight shifting tank drive. However, we found that in low gear, while the robot was technically putting out nearly 12 times more torque than in high gear, the wheels could not gain enough purchase on the carpet and thus put out about the same amount of force as high gear.
If anybody has experienced similar problems, please share. Our prototype is running on a fixed ratio, and runs pretty well, so it seems that a fixed ratio is better than a shifter.
"The glass is neither half-full or half-empty. It is twice as large as it needs to be."
"Any job worth doing is a job worth dying for."
Unread 07-11-2007, 10:23
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Re: To Shift or Not To Shift, That is the Question
Adam please seach before you post this topic has been discussed many times. To answer your question though it all depends on the game and how your team wants to play it. Generally 2 speeds has been worth it lately bcuase of the need to move quickly to get an object then slowly to score the object. In addition two speeds don't always have to be heavy look at servo shifters and 254's 2007 gearbox. There are also swerve drives which don't require 2 speeds at all becuase you can simply move away or around the 6 wd and 8 wd robots. In conclusion do your research on this topic, look at your teams manufacturing capabilities and analyze games/robots from the past. Good luck this is always a tough question this time of year, my team is shifting for 08 just to let you know. As for as your wheels/treads slipping look up PID loop control and research wheel materials. Speeds vary from year to year and team to team, we find that 8- 9 fps with one speed running two Cim motors per side works well. Shifting is a diffrent story the 1251 2007 robot is 3fps and 13 fps but generally we like to keep it around 6 and 12. Speeds depend on your drivers really I know alot of teams use 7 and 14 quite frequently.
Just a few thoughts ,
-Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Last edited by techtiger1 : 07-11-2007 at 10:31. Reason: wanted to answer the rest of the question
Unread 07-11-2007, 12:40
Nevets Amstier's Avatar
Nevets Amstier Nevets Amstier is offline
Dont Hesitate
AKA: read my username backwards
FRC #0155 (Technonuts)
Nevets Amstier is a name known to allNevets Amstier is a name known to allNevets Amstier is a name known to allNevets Amstier is a name known to allNevets Amstier is a name known to allNevets Amstier is a name known to all
for the past two season 177 has used 2 speed gear boxes which helps get to wherever you want to go quickly, then if you want to be precise or push someone around you can shift down.
it really depends on what your team wants to accomplish while playing
CLAKSON UNIVERSITY CLASS OF 2011
2012-?: Technonuts team 1552008-2011: Division By Zero team 229
2006-2007:Bobcat Robotics 177
Unread 07-11-2007, 13:17
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Often you will put out the same amount of maximum pushing force in low and high gear because generally your wheel/tread material stays the same. (shifters with designs like 67's in 2004 being the exception)
The benefits of shifting generally are that:
1) The motors are loaded less in low gear
2) You can go very fast for covering ground
3) You can go very slow for accurate driving
Ideally, your wheels would slip at about 40A current draw from each motor so that you don't pop a circuit breaker and lose mobility; thus, with the most popular tread material (CoF 1.0) this means you (assuming a four chiaphua drive system) must go at most about 7-8 ft/s. 7-8 ft/s happens to work pretty well as a middle ground speed, but if you have higher traction tread such as as SBR Roughtop incline conveyor belting, that number becomes something more like 5-6ft/s. That is too slow for many teams; thus, they shift. The shifting then frees you up to have both ideal current draw in low gear and a blazin' 16ft/s high gear. As you can see building an effective two-speed drivetrain doesn't only consist of making (or buying) a good shifter, but also choosing the correct ratios for your drive system. (arguably, the latter is the hardest of the two issues)
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 07-11-2007, 13:30
Unsung FIRST Hero
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Rookie Year: 1999
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
Here is a rule of thumb that I have developed over the years.
You want to gear your drivetrain to go as fast as you can but still spin the wheels/treads when you are up against a wall.
<EDIT> If you want to go faster, you need to a multi-speed gearbox.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 07-11-2007, 14:16
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
I think the benefit of a two speed transmission was best exemplified by teams 1114 and 330 last year (I'm sure there were others as well). Both used multi speed transmissions and both were very great robots. They used speed to maneuver around the field and beat defenders who were playing closely. They used low gear to push around robots that played closer to the rack.
A two speed transmission will make it easier for the driver... I am not saying that it will do the trick by itself, but if you have a driver that can handle it, you can really work it to your advantage.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 07-11-2007, 14:32
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Has anyone ever experimented with having a sort of automatic transmission system? So, when the driver moves the joystick between neutral and halfpower, it's in low gear, but then it will automatically switch to high gear if you put the joystick to full forward? Or does everyone use a manual transmission controlled by a switch?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 07-11-2007, 15:25
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Team 33 did this with their 4 speed transmission in 2004. I think team 368 used a similar design in 2005. You might want to search for the threads about 33's transmission, as i believe they discussed the autoshifting in depth
2001-2004: Team 100
2006-Present: Team 254
Unread 07-11-2007, 17:41
AndyB's Avatar
AKA: Andy Burchardt
I'm not a driver, so keep that in mind, but it seems intuitive for me that it would be nice on the joystick to have it default to low gear and then when the trigger or a button was held, it would shift to second gear, when it is released, back to first... kind of like a turbo button.
I say this because in my opinion, low gear is for precise driving and motion and high gear is for moving quickly between two points.
Unread 07-11-2007, 20:48
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
You don't necessarily need the low gear for precise movements.
Last year we had a single-speed transmission that was always running at 75% power, unless we pulled the trigger, then we put out 100% power.
Same idea, a little bit simpler, however, you do lose some pushing power with that 75%.
In the past year, it became quite clear to me that you don't necessarily need to be able to push, you just need to be able to stay still when you want to. If you can get enough momentum, then a single-speed transmission can knock someone off target. You do have abide by the rules of no "long distance, high speed ramming".
Originally Posted by Koko Ed View Post
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 07-11-2007, 21:07
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
That's true, but it sure helps....
As a former driver, based on experience with our previous years robots, the jerkiness of trying to make precise turns with a drive geared at 7-8fps (or higher) was kind of annoying. Now, I know a better designed drive (or one with less traction.....) could have helped, but that isn't all ways as easy as just bolting on a 2-speed.
Unread 07-11-2007, 21:09
wilmo's Avatar
wilmo wilmo is offline
FRC #0868 (TechHOUNDS)
Team Role: Leadership
wilmo will become famous soon enough
Thumbs down Re: To Shift or Not To Shift, That is the Question
we had a 2 wheel drive with the AM Gen-2 Servos. We tried shifting once, and we almost fell over from the sudden burst of speed, wasn't worth the weight for the 07 game, rather have more tanks for air
pic: Vex shift on the fly transmission Barry Bonzack Extra Discussion 1 30-04-2007 18:40
Making the KOP gearbox shift sanddrag Technical Discussion 4 26-03-2006 23:27
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
To shift or not to shift? sanddrag Technical Discussion 61 15-04-2003 22:56
