Go to Post Or use an IFI control system and you won't have to wait 2 minutes to use your bathroom :P - Chris is me [more]
Unread 09-11-2007, 11:33
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Cool Frame Ideas?
Originally Posted by Hachiban VIII View Post
I've always wanted to build a robot that way. I <3 Fiber Glass
1024 has used fiberglass in numerous applications for guarding fragile components...
Maybe the best and most visible use was to guard our camera in our 2006 robot. One of our members was also on the football team that year and brough his helmet in... which he sat on the top of the robot over the camera. I looked at it... yes it worked but... then i picked up the helmet... well lets say we could have had an extra frame rail in the robot.
But I digress. Yes, I agree with fiberglass being a spectacular robot material. It's easy to work with and requires a tiny amount of equipment to do well, none of which is costly. It's also easily repairable (west systems makes a great repair kit which can be bought in bulk if you plan on using fiberglass a lot, a hefty investment at first but well worth it + lasts you through a lot of holes/cracks).
1024 will eventually try experimenting with carbon fiber... as soon as we get someone to donate/get cheaply a large industrial oven.
Our 2006 robot was probably one of my favorite frames ever... it was simple but it worked. The cool thing was the frame rails (machined out of 1/2" thick 6061-T6 post-consumer aluminum) also had the bearing nests in them for the tracks, and the end of the frame had a tongue-and-groove section to allow for track tensioning (the last part of the frame was a seperate part that slid into it). The two frame rails were joined by a 1/16th inch thick aluminum sheet metal box that was riveted to both sides. Held together great through a season of slamming into the ramps at the last second... man I loved the 2006 game.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 09-11-2007, 12:03
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Anything from 1501 is pretty much a sweet frame design whether it be monocoque like previous years or their sweet chromoly design this year.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 12-11-2007, 11:14
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Team Role: Coach
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
I don't know about these ovens you speak of.
-q
I was referring to what Qbranch mentioned...
-q
While in industry, autoclaves and ovens are often used, you can still get a good cure from building your own hot box.
2005 Our entire arm was made from honeycomb laminated carbon fiber that was resined together at the joints.
-q
That's the kinda thing that would be interesting to make. Do you have any pictures?
Work Hard, Have Fun, Make a Difference!
Unread 13-11-2007, 18:14
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
Search before you post I got this picture off of your own team's website!
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 12-11-2007, 01:18
Doug G's Avatar
Coach / Teacher
Team Role: Coach
Get a piece of foam, carve it into the right shape. Add some spruce spars for extra structural suport. Cover it with fiber-glass or carbon-fiber, resin the whole thing and cover it with seran wrap to get it nice and smooth.
Then peil off the seran wrap an you'll have a nice smooth, strong, and earodynamic frame. And depending how well you squeeze out the excess resin - light too.
We may try some more composite work this year. Last year we learned how to do some basic layups and such, but it would be really cool to build an arm or more interesting mechanism out of carbon fiber rather than a square ramp, which rarely got used. Unlike what someone said, you don't need a large oven, you can build a simple one with just heat lamps. You just need to get the temp up to around 100 or so. Last year we turned a tool closet into a "hot box" to cure our ramps.
Unread 12-11-2007, 01:39
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
In past three years, our team has welded together an aluminum frame (hot metal, flying sparks, random passerby blinded over the shield at 8:30pm, what's not to love?). Last year, we had it professionally done when we realized something was wrong with our MIG, and our team spent more time fixing it than actually welding. Usually the students weld... This type of frame is sturdy, bottom-heavy and we can always include our traditional 10-degree wedge, but can cause difficulties in adjusting or repairing the drive train. This year, we're going to try to design a frame that is just as sturdy but doesn't require extreme flexibility in the hands or a robot tipping to fix the drive train.
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 12-11-2007, 02:13
run the trap!!!
Team 100 has used carbon fiber many times in the past. Usually we've just connected the pieces with resin and fiberglass.
-1995 We built our drivetrain out of a single piece of laminated carbon fiber with holes cut for wheels.
-2005 Our entire arm was made from honeycomb laminated carbon fiber that was resined together at the joints.
-2006 Our electronics board was made from honeycomb carbon fiber.
-2007 The v.2 "Head" (our manipulator) was made from a combination of wood and fiberglass with reinforced carbon fiber edges.
I'm personally not a big fan of the stuff. It takes special drill bits and saws to cut. And the edges are razor sharp, and can easily cut through wires and flesh !
But if you're still interested in using it check out your local Tap Plastics, or The Robot Market Place. I know in the past it has always been donated to us by Battlebots builders.
I tried to get a local bike shop to sponsor us last year and build our frame out of carbon fiber (using the same techniques they use to make custom bikes). But they were neither enthusiastic nor happy about spending thousands of dollars on us So it fell through...
-Philip J. Fry
Unread 09-11-2007, 01:02
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Originally Posted by Binome View Post
Bosch Extrusion
Its really nice, and reusable between years.
You probably don't want to hear this, but I'll bring it up anyway....
Based upon past years' rules, and the ways that they've typically been interpreted, only the most trivially modified extrusions are actually reusable under the rules. Basically, for a part to be reusable from year to year, it needs to be COTS and unmodified. In the case of extrusions, while the different kinds of custom cuts that are possible make interpretation of the rule a little fuzzy, things like milled slots or bolt patterns are almost certainly going to be ruled as non-COTS, and therefore not legal for next year's robot. So be careful what you reuse!
Originally Posted by dtengineering
If you can't TIG or MIG in-house, then keep in mind that somewhere in your community there is someone who wants to weld your robot for you. People who like welding tend to like welding cool things, and competitive robots are generally regarded as a pretty cool thing. Perhaps a local community college or trade school can help you out.
That's exactly what 188 tried one year (2006). We ended up with a very unconventional welded sheet metal frame. We also had a few too many crazy robot issues happening simultaneously, and nothing on that robot really got fine-tuned very well. Despite that, I'd like to see more of that sort of semi-monocoque aluminum frame—not because it's necessarily the most effective, but because it's an interesting engineering challenge. In the case of the 2006 robot, 188 recruited the services of a local engineering and fabrication company, but the community college suggestion is an excellent one. (As a matter of fact, for teams in Southwestern Ontario, there's a nice welding lab at Conestoga College in Guelph that might be worth talking to—I can supply contact details if anyone's interested.)
One last thing about welding aluminum: by virtue of the way aluminum heat-treatment works, fusion welding (i.e. when metal melts) almost invariably results in a weld that is weaker than the base metal. So even though you might be welding 6061-T6 extrusions, you might have to use a welding rod that deposits 4043-O filler metal* (which is far weaker). There's one thing that would be even more impressive than trying the fully-welded chassis: building a frame jig which would hold the entire frame rigidly while you heat-treated it in a large oven, back to a high-strength T6 condition.
*More precisely, it's actually -F with properties equivalent to -O, because it wasn't deliberately annealed, rather it just came out that way.
Unread 09-11-2007, 13:03
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Bosch Extrusion
2007 was the first time 342 didn't use a extruded aluminum (FMS) frame and we won the Palmetto regional for the first time after competing for 7 years (couldn't have done it without 1319). FMS is useful, but a major pain in the butt. Our whole pit and transporter are made from FMS and we constantly have to tighten stubborn bolts.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 09-11-2007, 13:35
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
Rookie Year: 1997
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
222 has a prototype bot to play the 07 game built from 80/20 quick frame and 1/16" lexan. The quick frame is basically 1" aluminum square stock with .060" wall. The connectors used to assemble the frame are made out of nylon. The prototype bot is going to its second competition this weekend(we won BE 6 last weekend thanks to our partners 1626,25 and 1923 for picking us) . It's been through one competition and so far so good. I will be writing up some more detailed information on this frame when we disassemble and check for stress on the nylon joints. So far we're convinced the 80/20 quick frame makes a good, strong, light, and easy to assemble frame. I will post more information as soon as I can.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 09-11-2007, 14:20
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Would you mind sharing from where you're getting the nylon connectors? I've been investigating using something like those recently and haven't found very many sources for them. I'm trying to get an idea for what's available, at what cost, and what the lead times are like for getting them delivered.
Thanks if you can help
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 09-11-2007, 14:34
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Your local 80/20 distributor should have them. The tube is $0.13 an inch (it is a special square extrusion with ridges on the inside of the tube, which I assume increase the strength of the connection) and the connector price varies depending on which one you get (straight through, t connection, 6-way, etc), but they all are between $2 and $3 each. My copy of the 80/20 price list is from last March so prices may have changed a tad, but these numbers should be pretty close.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 09-11-2007, 15:36
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
I didn't even think that it would be produced by the same folks that market the T-slot extrusion. Thanks.
Has anyone used these connectors with more conventional 1x1x.0625" tubing? I'd rather not need special tubing when I've got a local supplier for metal stock and a few dozen feet sitting in the workshop already.
--Madison--
Unread 09-11-2007, 16:25
AKA: Cliff Mock
Rookie Year: 1997
You might want to check with someone on 1089 I know they use the connectors, but I think they are using standard aluminum. I will caution you though, the 80/20 tubing is ribbed on the inside to grip the nylon connectors better. Also I've been using http://stores.ebay.com/8020-Inc-Gara...Q3amesstQQtZkm
this store on Ebay. They have a pretty decent turn around time most parts ship in a day or two and you can generally find parts cheaper through them.
  #15   Spotlight this post!
Unread 11-11-2007, 21:35
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
Madison et al.
We have used 80/20 QuickFrame extensively for the last two years. We haven't used it for the chassis but for most all of the other structural components. It is really great stuff and easy to work with. All you need is a miter saw and a rubber mallet. If you want to take it apart heat the aluminum near the connector with a propane torch to expand the aluminun just a little and then the connector will usually slide right out to be reused. The only downside is the plastic connectors aren't exactly light and can start to add up if you are trying to squeze out that extra pound or two of weight budget. We bought a bunch of stock and connectors in 2006 and will probably need to restock some this year. I don't know where everyone else buys their 80/20 material but we went through our regional distributor and they gave us quite a nice educational discount. IIRC it was something like 40% and I was under the impression this was the standard 80/20 discount for all FIRST teams.
As far as using the connectors with standard 1" thin walled square tubing I really don't think it will work. The 1" square 80/20 QuickFrame tubing is specially fitted for the connectors. It has longitudinal ribbing inside that forms a friction lock with the plastic connectors. This is sort of the secret to the whole system. The internal dimensions of the QuickFrame tubing is slightly smaller (thicker walled than standard 1" thin wall box tubing) so if you try to insert a QuickFrame connector into standard 1" thin walled box tubing the connector will just fall out (too loose). The tubing isn't really that expensive though. IIRC the standard 1" QuickFrame box tubing was about $10-$11 per 12 foot (145") piece after the discount. They also have tubing with flanges on the side in different arrangements for putting panels in, etc. We purchased some but didn't really use the flanges much and often just cut them off to save weight.
One trick we found was to drill a hole in the end of the tube through into the connector and put a pop rivet in on any connectors you REALLY don't want to back out. This trick is rarely needed but is cheap (and light) insurance.
There are also 80/20 "transition" connectors available to use QuickFrame in combination with 1010 series where needed.
Search CD media photos for our team number "456" and there are 4 photos, 2 of our 06 and 2 of our 07 (1 lifting our 06) robot showing lots of use of 80/20 QuickFrame.
Oh yeah, we have used the KitBot frame for the last two years but the QuickFrame matches perfectly to the 1/4" 1" spaced hole pattern of the KitBot frame if you use the little base connector (part number 9140(gray) or 9240 (black)).
Hope this helps. Any more questions just ask.
Edit: I forgot the mention that 80/20 QuickFrame isn't really made by 80/20 but rather by Esto.
the frame kaboose Technical Discussion 7 11-01-2007 22:38
Riveting up a frame Billfred Technical Discussion 27 19-12-2006 19:49
Cool new ideas for FIRST Robots - who has them? sanddrag General Forum 44 04-08-2005 15:02
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
