Go to Post Coaxial swerve modules with a suspension and differential aren't normal. But on Winnovation they are. - Andrew Schreiber [more]
Unread 12-11-2007, 10:08
steadfasttuna steadfasttuna is offline
AKA: Hamzah
FRC #2468 (Chap Robotics)
Team Role: Mechanical
Rookie Year: 2007
steadfasttuna is a glorious beacon of lightsteadfasttuna is a glorious beacon of lightsteadfasttuna is a glorious beacon of lightsteadfasttuna is a glorious beacon of lightsteadfasttuna is a glorious beacon of light
Transmisson?
Anyone have schematics for a 3-speed transmission made out of a cordless drill?
Unread 12-11-2007, 10:29
Billfred's Avatar
Billfred Billfred is offline
Re: Transmisson?
Yup.
http://www.chiefdelphi.com/media/papers/1592
Unread 17-11-2007, 16:52
roach1051's Avatar
roach1051 roach1051 is offline
Go Boilers!
AKA: Jack Roach
FRC #1051 (Technical Terminators)
roach1051 is on a distinguished road
Re: Transmisson?
We used the white paper as a reference to use the Dewalts in 2006. They worked fine. We even used a single Dewalt trans with two CIM motors on the input side. We built a custom dual motor mount and 3:1 reduction gears that fed into the single Dewalt trans that we shifted with the servos in the KOP. It was a pretty good system. The beauty of the Dewalt trans is that it is very light, especially compared to last year's Banebot trans.
Unread 27-11-2007, 15:07
AKA: Hamzah
Rookie Year: 2007
Re: Transmisson?
thanks guys
Unread 27-11-2007, 17:29
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: Transmisson?
Our team is doing something similar to this. Do you have any pictures you can post, or any tips on making this work. Any information would be appreciated.
Thanks
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
