pic: 114 6wheel tensioner
Re: pic: 114 6wheel tensioner
This is a fantastic chain tensioner system, hard to believe no one's replied to this in 6 months. On our prototype frame, our tensioner mounts are designed to be maintenance-free as well, but it's not nearly as elegant as this. Nice design!
Hmmm... So it is kind of the inverse of the older style of tensioning the "west coast drive" (like 968 last year)?
I like it. |
This is pretty much exactly like what 968 did in 2006, I think.
Okay, some questions...
What size and thread was the bolt y'all used for tensioning? I'm presuming the attachment bar was tapped for that bolt. It looks pretty thin, so I'm curious how many threads you had engaged to keep tension in the chain. Did you have any problems with it vibrating loose during a match? |
We just used a 1/4 20 bolt. It held fine. The plate closest to the wheel was tapped, and 1/4inch thick. The other plate is not tapped. We only had to tighten the bolts once per competition: right before any final match. It's a wonderful setup. This variation is a bit heavy, due to two bearing blocks. I've since redesigned it to only need one frame rail, as well as only one bearing block.
This design, with two bearing blocks, yields a beastly solid frame, but at the cost of too much weight. The singe block design is much lighter, though less beefy. Are you thinking of maybe using this design? |
I've been working around a 3/8-16 bolt since it's going into plastic. Coarse, big threads are the order of the day for us. |
We used this method on a few robots, the first I think was back in '97 or '98. The only drawback is when you run out of adjustment room, you have to remove a link in the chain. So the adjustment range needs to be a little greater than one link in length.
If like 60, we used that tensioning setup with a #10 and it wouldn't vibrate loose that much. Usually 1-2 times a regional we'd check and the chain was slightly loose, we would it half a turn or so, and be good to go. We use the same concept on our with no problems (also ran it in 2007, had to tighten it about as much as in 2006). So, short answer. No, it shouldn't loosen much and it should work just fine. Over the various years we've used this method, I've never seen it loosen so much over the course of one match to actual cause any problems. |
#10
When in doubt use a locking nut to prevent any movement. Loss of tension can be disasterous.
#11
We were considering a method of capturing the bolt head and preventing it from rotating, but it's a bit of challenge to devise such a system that allows enough flexibility in where the bolt head lies to make using this for tensioning practical. |
#12
McMaster sells bolts with a nylon patch on the tip-eliminating the need for a locknut.
However, I have no idea if they work/work well in plastic. |
#13
I don't think a nylon lock nut or bolt is even necessary. We used this system with no locking methods at all, and it worked wonderfully.
I look forward to seeing pictures on how you all implement this! |
| pic: Kitbot Chain Tensioner 2 | Donut | Extra Discussion | 13 | 10-12-2007 15:57 |
| pic: 114 Tread V 2.0 | CraigHickman | Extra Discussion | 4 | 08-01-2007 01:34 |
| pic: Kitbot Chain Tensioner 1 | Donut | Extra Discussion | 6 | 21-12-2006 00:43 |
| pic: 114: Stripped! | CraigHickman | Robot Showcase | 5 | 04-04-2006 23:49 |
| Chain Tensioner? | Gabriel | Technical Discussion | 14 | 29-01-2004 09:16 |
