Go to Post Gosh, I wish that we would've named IndianaFIRST after a candy. - Andy Baker [more]
View Poll Results: What version control tool(s) do you use?
SVN 22 61.11%
CVS 6 16.67%
VSS 0 0%
Other please post 5 13.89%
None 3 8.33%
Voters: 36. You may not vote on this poll
Unread 29-11-2007, 14:47
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
I've been using SVN for some time, but I'm starting to have issues. I have been using TortiseSVN, which is a great tool, connected to a file system repository on a network share or external drive or some type. This is an acceptable system for small projects, but when I need to be able to colaborate with others it is often nessisary to have a secure repository on the internet. I host several websites already, all running on IIS7, so most of the hosting issues should have been solved, but no.
SVN is only compatible with Apache and IIS and apache don't play well together, so if I want an SVN server then I would need to either migrate all of my existing websites to Apache or, run the SVN server on another machine. Neither of these options are practical.
I also can't afford to pay for SVN hosting by someone else.
So, finally to my question. I'm looking for alternitives to SVN, or at least a way to host it.
What version control tool(s) do you use, if any, and you do use one does it work when IIS is installed, or even on Windows?
Thanks,
Eric
Eric Haskins KC9JVH
What programming tool does your team use? ham90mack Programming 15 13-10-2007 15:52
What tool are you using to make weight? EricH General Forum 40 27-02-2006 19:46
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
What view do you use? Brandon Martus CD Forum Support 10 02-12-2003 17:32
What do you YOU use your bins for? AlbertW General Forum 40 13-04-2003 04:18
