Go to Post Students can learn to drive on whatever they give us. Ramps, carpet, grating, HDPE, lexan, diamond plate, regolith, other robots the driver station wall, referees, stairs, Dean, the bar, goals, the scorer's table, you name it, I've watched robots somehow manage to drive on it - Peter Matteson [more]
Unread 30-11-2007, 16:54
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Position idlers to get better chain wrap -- a question about good practices.
So, I guess I'm looking for words of advice and consolation as I deal with trying to elegantly tension chain and achieve good wrap around my drive sprockets.
Assume that tensioning is achieved by moving the outer drive wheel and sprocket away from all of the others -- toward the end of the robot. The idler is attached to the frame rail and is fixed in place.
How close can I reasonably put the idler to the gearbox output sprocket (shown floating in space) to achieve increased chain wrap without it being so close that the sprockets are acting as spur gears, too.
Are there any situations that may arise from creating serpentine chain wrap, speaking generally? I've never designed such a complex chain run before; and I realize it's not even that complex.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 30-11-2007, 17:33
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Re: Position idlers to get better chain wrap -- a question about good practices.
Maybe I don't understand what you are saying, but why not try this? I made it in Paint in about 10 seconds, so don't kill me...
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 30-11-2007, 17:41
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
Well, I guess I'm trying to find out what sort of advice or experience folks have with such an arrangement -- which is really just an extreme case for what I have on my model. It seems to me that, as you increase chain wrap with such a setup, you correspondingly increase the chain's desire to tear the idler off its mount entirely. I'm just curious to learn what folks have found to be a happy medium or that I'm concerned for nothing.
--Madison--
Unread 30-11-2007, 17:49
RyanN's Avatar
RyanN
Well, this is true. We broke the shaft holding on our idler last year, but it was really a bad design flaw because the metal was so thin where it broke. The amount of force on the idler is a lot (I think our engineer was saying that we had over 400lbs of force on our idler) We ended up replacing our lathe built idler bolt assembly with just a plain 'ole bolt that worked for the rest of the regional.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 30-11-2007, 18:05
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
We used a serpentine chain-wrap system in 2006 and it was a disaster. The chains fell off, they even broke! We had a six motor drive train and so much of the power was lost to friction that we barely had any pushing power at all!
I'll never use tensioners of any kind again. Not in the drive train, on the arm, or anywhere else. Moving the axels is a far more elegant and efficient solution.
And yes, I realize hundreds of teams use tensioners just fine. Thats just my opinion.
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 30-11-2007, 18:12
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
That's weird.... we had a serpentine wrap in a six motor drive and there we no problems. Never had a chain derail, ever. We still had great pushing power as well, no more power loss than a regular setup.
Unread 30-11-2007, 18:30
RyanN's Avatar
RyanN
You won't have trouble with chain if you have the correct setup. Little sprockets save weight, but they put more tension on the chains, allowing them to snap. The constant forward and reverse of our robots makes the chains slap around, often derailing them, so use guides (we make our own nylon guides, and haven't had a chain derail since 2005. Just my advice...
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 30-11-2007, 18:47
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
From the pictures in FIRST Robots: Behind the Design, it appears that the idlers that 100 had in 2006 consisted of cylinders of plastic (looks to be polyethylene or maybe nylon) so it isn't really a big surprise to me that it had high frictional losses. On the other hand, we have used ball bearing idler sprockets for the last two years, and they spin really easily even with a significant amount of force applied to the chain.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 30-11-2007, 19:00
AdamHeard's Avatar
Lead Mentor
oh man.... dont have my book with me, but that much wrap on plastic rod seems like a lot of friction. No wonder.
Unread 01-12-2007, 01:27
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
Actually if they did it right there might not have been much friction at all. The trick is to install the rod in such a way as to make sure the chain is tight and then let it "wear in" a slot on the plastic rod. You migh want to pre-wear a groove in the rod to make sure the chain stays put, but it probably is not necessary. Once the tight chain wears into the rod a little bit it will go slightly slack. It will then cease to wear and the friction will be negligible.
Another approach is to not use tensioners at all. We have done this the past few years. In this case you need to be able to locate the sprocket axles precisely. You need to design the chain loop to have an integer number of links and preferably an even integer.
If there's interest I can do a white paper on how to do this.
Chris
Christopher H Husmann, PE
"Who is John Galt?"
Unread 06-12-2007, 13:21
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
If you can mount the drive motor/trans assembly midway between the wheels AND have it mount such that it can be moved vertically slightly, you could use a double-row drive sprocket and two independent chains. Each chain run is shorter, which seems to reduce tensioning problems. To tension it, just loosen the drive assembly and shim it up slightly. Team 975 has done this a couple of years. Tensioning with #35 chain was rarely required, and slipping a thin washer or two between the drive mounting plate and the frame seemed to take up more slack than you'd imagine.
http://www.chiefdelphi.com/forums/at...d=119696522 0
Name:	chain tension.jpg
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 06-12-2007, 18:03
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
http://www.chiefdelphi.com/media/photos/27587
Here's a picture of our drive last year. I think it's similar to what you are looking at doing. We had zero problems with this and it worked very well. So well in fact, that we are using a version of it this year. Hope this helps.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 30-01-2008, 14:48
deejay021's Avatar
deejay021 deejay021 is offline
AKA: David C.
FRC #2549 (the millerbots)
deejay021 is an unknown quantity at this point
Send a message via AIM to deejay021
ok so i had a quick question... with te tough boxes we recieved a sprocket that fits perfectly ont the box... however the output sprocket is at least 2x the size of the input... so... for every rotation in the tough box we get .5 on the actual wheel...for a 1st year team we are trying to get a drivable robot thatd be a decent accomplishment in out eyes... and we are working towards that but a faster driving robot would be nice...
and my second question is actually relevant to this forum... where do you get idlers... and any ideas on mounting them?
Unread 30-11-2007, 18:43
run the trap!!!
There's a nice picture of the setup on page 45 of FIRST Robots: Behind the Designs.
-Philip J. Fry
  #15   Spotlight this post!
Unread 30-11-2007, 17:37
AdamHeard's Avatar
Lead Mentor
In 2007 we had an two 10 tooth sprockets stacked vertically with about 3/8" clearance between them. We had no problems with it at all. The chain was coming in about 30 degrees off horizontal from each side (30 degrees towards the side that gave it more wrap).
Hope that helps. The mentor who designed it with us was from 687 and he had build a lot chain driven robots in the past and I believe he said as long as there is room for the chain to go trough, there won't be problems.
Computer good practices vivek16 IT / Communications 25 21-11-2007 10:50
pic: A Better View of Racky With All Cylinders in Stowed Position DanDon Robot Showcase 2 20-02-2007 21:06
Rules about pressure gauge position Kamen64 Rules/Strategy 1 06-02-2007 19:15
FIRST 2007 GUIDELINES, TIPS, & GOOD PRACTICES dez250 General Forum 3 09-01-2007 20:26
Do you get to choose your startin position? Nitroxextreme Rules/Strategy 3 05-03-2005 00:44
