Go to Post If you don't have a butt to fill that seat, you don't need it. When the butt arrives, we'll make room. - DonRotolo [more]
Go Back   Chief Delphi > Other > VEX
Unread 04-12-2007, 14:16
VEX Drive Trains 2007
Just curious as to how teams are making their drive trains this year. Post gear ratios, wheel size, chain/gear driven, other opinions. Attatch pictures of the drive train as we need a little help for new drive train ideas. Also feel free to post up your own questions. Thanks in advance! Post up your end effectors if you wish also. Hope everyone is having a great season!
Unread 04-12-2007, 15:03
Cartwright Cartwright is offline
Scouting/Manufacturing
AKA: Jamie
FRC #0234 (Cyber Blue)
Team Role: Leadership
Cartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to behold
Re: VEX Drive Trains 2007
We have a six wheel drive system, that has a rock in it for maneuverability. We are driving each side with two motors and we're using medium and small gears. We thought about chain, but it's just not sturdy enough for us.
Sorry...no pics.
Unread 04-12-2007, 15:25
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Team Role: Mechanical
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
4 motor 4 wheel 36:12 gear ratio using two large wheels and two medium omni wheels.
Unread 04-12-2007, 16:07
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
546 had a 12 wheel 6 motor drive train this year using small wheels and a gear tooth ratio of 36:12. The four end wheels were raised for a better turning radius... the only problem was power! (and axles sliding out of clutches due to untightened lock collars) I think we have a picture somewhere...
Here it is!
Unread 04-12-2007, 16:17
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
Rookie Year: 2007
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
2 module crab drive, small wheels then 2 small wheels without tires for casters, actually works pretty well
Unread 04-12-2007, 16:18
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Team Role: Teacher
Rookie Year: 2007
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Team 183 is also a 6 wheel bot, it rocks as well for maneuverability but we elected to only drive 4 of the wheels and make the other two "free wheeling" omnis.
Unread 04-12-2007, 16:26
Sorry...no pics.
Yea, we tested with chains a few times in different orientations but it just wasn't strong enough. Right now our robot pushes around 30 lbs on carpet with hardly any weight on the robot itself. Also, we've been looking at 2 speed transmissions b/c we have the power but we definitely need more speed for this game. And we began focusing on the end effector.
Unread 04-12-2007, 16:59
rswsmay's Avatar
rswsmay rswsmay is offline
AKA: Robert
FRC #1177 (Mecha-Jags)
rswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the rough
Our team has not yet fully decided on a design yet. We are considering various design concepts and are working toward prototyping each one before selecting a final design. We have decided on a multi-speed drive train which we have already built and tested. We are also prototyping an ackerman steering system which we hope will improve drivetrain performance during turning manuvers. We completed some preliminary calculations, worked out the geometry and built 2 prototypes this past weekend. In conjunction with this, we plan to develop a software program to drive the wheels on both sides of the robot (actually all 4 wheels independantly) at the necessary speed to minimize skidding/dragging.
We are also toying with developing a 4 wheel steering system, but have not worked on any of the mechanics for that yet.
Knowledge is only strength.... Knowledge and Wisdom, thats true power.
Unread 04-12-2007, 17:08
fredliu168's Avatar
fredliu168 fredliu168 is offline
FTC #0478 (Mustang Robotics 478)
fredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud of
Send a message via MSN to fredliu168
6 wheel all-purpose wheel gear drive. 1:1 gear ratios on the drive.
In 2006
Team Name: 3652 FLAME
Michigan VEX Competition WINNERS
Pennsylvania VEX Competition WINNERS
Atlanta World Championships Runner-up alliance
Only team to win two regionals in 2006
In 2007
Team Name: 478 Mustang Robotics and 163 UHS Robotics
Events:
Toronto FTC Competition - Finalists (478, 163, 298)
MA FTC Competition - Winners! (738, 478, 427)
Unread 04-12-2007, 17:27
Currently working on that but with 4 wheels. Which tooth gears did you use though?
Unread 04-12-2007, 22:14
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
Team Role: Coach
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
i not in vex I'm in FRC and i just so happen to have a vex robot i just figured out how to do swivel drive with one wheel and two omni wheels so now I'm going for two swivels and then the next project will be 4 swivel wheels...
Curie..
Unread 04-12-2007, 23:43
fredliu168's Avatar
60 tooth, alternating gear/wheel
In 2006
In 2007
Events:
Unread 09-12-2007, 20:13
shsroboticsclub shsroboticsclub is offline
FTC #3675
shsroboticsclub is an unknown quantity at this point
Two speed transmission with a special type of steering, I wont say just yet. oh and four wheels.
Unread 11-12-2007, 22:37
Anyone plan on de-scoring? Or is anyone already capable of doing so?
  #15   Spotlight this post!
Unread 11-12-2007, 22:44
Emily Horsman
Rookie Year: 2007
correction to my teams drivetrain
6WD!!!! way better than swerve, it turns out the my autonomous sucked with the swerve (you know how the motors always 'twich' when you turn on the robot) well that screwed it up pretty bad
paper: FIRST Drive Trains and Structures Madison Extra Discussion 18 04-12-2007 17:37
Drive trains Jared Rillings Rules/Strategy 2 10-01-2007 13:17
Vex Announcement: FIRST Vex Challenge Extended for 2006-2007 KathieK FIRST Tech Challenge 14 30-07-2006 23:42
what do i need to know about drive trains angier314 Motors 1 16-01-2003 12:43
Drive Trains?!?!?!!!!! archiver 2001 0 23-06-2002 23:08
