Go to Post The Chairman's award is about doing what you can to strengthen the FIRST community. It doesn't require money to simply lend tools, wise advice or a hand. - Koko Ed [more]
Unread 06-12-2007, 23:01
CraigHickman
Posts: n/a
pic: What happens in the offseason...
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
FRC #0558 (Elm City Robo Squad)
jwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond repute
Re: pic: What happens in the offseason...
your robot for next year will have a skateboard drive train? what?
2003-2006 | FRC 0176 | Aces High - Student
2007-2010 | FRC 0229 | Division by Zero - Mentor in Training
2011-2013 | FRC 2168 | Aluminum Falcons - Mechanical Mentor
2013-20xx | FRC 0558 | Elm City Robo Squad - Mechanical Mentor
Unread 06-12-2007, 23:02
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
CADding whatever you have sitting around, is good practice!
Unread 06-12-2007, 23:03
CraigHickman
Posts: n/a
Actually, this is CADed from scratch. It's a precision truck of my own design. Soon to be machined.
Unread 06-12-2007, 23:43
Borisdamole Borisdamole is offline
mercernary machinist
AKA: Taylor
FRC #0973 (most with 973)
Team Role: Mechanical
Borisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really nice
Send a message via AIM to Borisdamole
what angle are the base plates? are you using 8mm or 10mm axles? are the hangers going to accept standard bushing, or are they custom bushing? Are you using a pivot cup or a spherical bearing? and how are the axles attached to the hanger(e.g. pressed in, screw in or cast in)?
OUTWORK US
Unread 06-12-2007, 23:47
CraigHickman
Posts: n/a
Hey, I found another longboarder! They're 42 degree plates, with 8mm axels. They're custom bushings, and it's a spherical bearing. The axels are knurled, loc-tited, and then pressed in.
Unread 06-12-2007, 23:58
AKA: Taylor
Talking Re: pic: What happens in the offseason...
well i like the design, but i would highly suggest trying a threaded axle with a pin that fits into a hole in the axle and truck. this would allow for the strength of threads, with out the possibility of backing out. also, make sure you make a recessed cup for your bushings!!!!
reminds me of this truck, and the axle with pin thing is on this truck also
http://www.landyachtz.com/D27.cfm?PID=257&place=3
OUTWORK US
Unread 07-12-2007, 00:05
CraigHickman
Posts: n/a
Yeah, there is a slight hole for the bushings. As for the axel attachment, I'm sure that knurling and loc titing will be plenty, especially because it will be press fitted also.
Unread 07-12-2007, 00:11
AKA: Taylor
What kind of board will you be riding this on? is it drop through or top mount?
is the truck drilled for new school mounting, old school mounting, or both?
OUTWORK US
Unread 07-12-2007, 00:18
CraigHickman
Posts: n/a
It'll be a top mount, drop deck speedboard, most likely. Have yet to make it. The truck is drilled for neither old school, nor new school, yet. It's still in concept phase, so tiny details like that are on the finalize list before I got into the shop to roll these off. It'll probably be new school when it is drilled, though.
Unread 07-12-2007, 00:27
AKA: Taylor
do u post at all on silverfish? I overall like the design, are you going to sell any? they overall look like a solid skate truck. What wheels are you planing on using? anything over 75mm, you should probably consider using heat treated axles.
OUTWORK US
pic: This is what happens when the parts aren't in. RoboDriver1718 General Forum 4 23-01-2007 09:03
pic: What happens when the Technokats go out to play... dubious elise Extra Discussion 9 28-07-2006 17:15
pic: This is what happens...... CD47-Bot Extra Discussion 14 16-06-2004 16:25
What happens to the broken parts after competitions? Greg Needel General Forum 4 31-03-2003 01:46
What happens to the ALUMNIS??? archiver 1999 8 23-06-2002 22:02
