Go to Post Definitely read through ALL the documentation, and if you still have questions, ask. - Joe Ross [more]
Unread 09-12-2007, 02:39
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: NED HELP ON BUILDING 1 OR 2 SPEED GEARBOX
Originally Posted by gburlison View Post
This gearbox has a 16 to 1 ratio using 5 tooth stem pinion gears on the CIMs and a 80 tooth spur gear on the output shaft. The use of a stem pinion gear requires a coupler since it is too small to fit on a CIM shaft.
Makes more sense. Is that one of yours, or did you just analyze it to death?
Edit: Yes, it is 662's 2007 robot. The discussion and original picture are here.
Edit2: Did you guys run into any issues? How much did it cost? What other info would help this team?
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 09-12-2007, 03:03
gburlison gburlison is offline
Mentor
FRC #0662 (Rocky Mountain Robotics)
Rookie Year: 2000
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Team2061 sent me a PM and I provided him more details, but the short answer is that it cost about $100. It is a simple one stage gearbox using the smallest stem pinions we could find (5 tooth) and the biggest spur gear practical (80 tooth). There is one main issue with this gearbox and that is alignment. The output shaft is supported in three bearings, so misalignment can cause binding. The first year we built this design, we used solid couplers on the CIMs and this also suffered from misalignment and binding. The Lovejoy Couplers took care of any possible binding of the stem pinion gears. Just for reference, this is our first Gen of this Gearbox. http://www.chiefdelphi.com/media/photos/19829
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 09-12-2007, 15:12
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
Originally Posted by team2061 View Post
I NEED HELP ON HOW TO BUILD A VERY EASY SIMPLE AND CHEAP GEARBOX FOR 2 CIM MOTORS. THEY CAN EITHER BE 1 OR 2 SPEED GEARBOXES W/ PNEUMATICS SHIFTER.PLEEEEEEEEEEEAAAAAASEEEEEEEEEE HELP.
Don't forget about the Dewalt shifting drill gearboxes. They're a lot cheaper than the AM shifters, and you can get three gears instead of two or one.
They are however... a little more fragile...
Also, if you just want a 1 speed why not use modified banebots? Or whatever else they give us next year?
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 09-12-2007, 16:18
DonRotolo's Avatar
Back to humble
FRC #0832
Re: NEeD HELP ON BUILDING 1 OR 2 SPEED GEARBOX
Some general advice from another team of PI-O-Neers:
I think 2-speed shifting gearboxes are cool, BUT unless there was a real need for them to excel at a particular game, I'd rather put my efforts and money into something else.
Resist the temptation to build a cool robot that doesn't do anything well.
Don
Unread 09-12-2007, 16:35
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
Team Role: Leadership
Rookie Year: 2007
team2061 will become famous soon enoughteam2061 will become famous soon enough
Don
You have a really good point, i think were are going to go with a 1 speed gearbox from andymark as oppose to making one. Thank You very much PI-O-Neer.
P.S I didnt think there was another team named pioneers in FRC. This is going to be our 2nd season
Unread 09-12-2007, 17:25
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Team 116 has posted designs of their 2002-2004 era 2-speed, crash shifter. While this specific design is now outdated (Bosch drill motor not included in 2005-2007 KoP), variants of this design are still used (379's 2007 shifter was based on this, as well as several other "descendants" of this transmission).
http://www.chiefdelphi.com/media/papers/1437
In 2007, Team 116 used the AndyMark gen.2 shifters.
Being correct doesn't mean you don't have to explain yourself.
pic: 114 2 speed Gearbox CraigHickman Technical Discussion 13 25-02-2007 19:41
2-Speed Shooter Gearbox JVN Technical Discussion 4 08-02-2006 13:52
pic: Vex 2-speed gearbox crazykid234 Extra Discussion 3 03-01-2006 20:18
TechnoKats 2-speed gearbox ebenhopwil Technical Discussion 17 27-06-2004 02:06
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
