Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
Unread 11-12-2007, 04:58
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Interrupts per second
Hello everyone,
I've been looking around the forums and have seen several posts but I haven't seen a definite answer. My team is designing a robot and we want to put encoders on it. Questions arose concerning the fact that encoders we have are 100 clicks/revolution, and we are planning on having the wheels turning at .7 - 1 rev/second, meaning 700 to 1000 clicks per second of the encoders * 2 sides. We were wondering, can the RC handle 2000 interrupts a second, in addition to whatever it takes to run the camera and essentially the default code?
Thanks,
--Ryan
Unread 11-12-2007, 07:22
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Interrupts per second
Ryan,
It all depends on how many (and which kind of) instructions are being executed in the interrupt.
Here is a good discussion on the time required to service the interrupt before your code even gets to run.
In general, keep the code short and 2000 interrupts per second should not be an issue.
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 11-12-2007, 08:24
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
Team Role: Leadership
Rookie Year: 2007
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
it should be fine, but if it isn't, banebots (just google it) has an encoder click reducer
Unread 11-12-2007, 09:50
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Just remember that 2000 interrupts per second is going to start running the risk of stretching PWM pulses on PWM13-16 if you're using the standard IFI Generate_PWMs() code. If you have any interest in using these PWMs, you'll probably want to transition to the CCP-based PWM generation code on Kevin Watson's site.
Unread 11-12-2007, 14:19
RyanCahoon's Avatar
Rookie Year: 2007
We're not using PWM13-16 and it's just going to be a counter on the encoder interrupts so it sounds like it will work. Thanks for the help!
--Ryan
Unread 12-12-2007, 00:57
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
If you are worried about processor overload from using too many interrupts in your program, you can also gear the encoders slower so you'll have less pulses per second. You'll start losing accuracy, but if you gear them slower by a 3:1 reduction you'll still have 33.3 pulses per revolution.
On a six inch wheel, that's an accuracy of about 0.56 inches per pulse. This should be more than sufficient for drive train applications, since that's within the tolerances of a FIRST playing field.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
10 Balls per second? Travis Covington Rumor Mill 103 26-07-2006 00:06
17 matches per team @ AZ? jpsaul7usa Regional Competitions 12 05-03-2005 22:12
Interrupts per second steven114 Programming 10 17-02-2004 13:59
Average Feet per Second MisterX General Forum 25 26-01-2004 21:03
Code cycles per second archiver 2001 2 24-06-2002 02:43
