Go to Post Oh man... 20% skinnier, 40% dorkier, ... if that's what turns into one of our best mentors, I REALLY need to find a new hobby. ;) - Rich Kressly [more]
Unread 14-12-2007, 16:43
mattotters's Avatar
mattotters mattotters is offline
leadership/fab team
FRC #1228 (A-MERK-IN-INDIANS)
Team Role: Mechanical
mattotters is an unknown quantity at this point
Send a message via AIM to mattotters
Mounting of drive system
On our bot the wheels has always been keyed to the axel shaft and this year we want to try to have the wheel spin on the axel we have the correct wheels set up i just want to know what is the best/most commen way to attach the wheel to the frame.
any tips pictures would be great =D
Unread 14-12-2007, 16:49
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Mounting of drive system
Ah, going from a live-axle (axle turns the wheel) to a dead-axle (wheel turns on the axle)? Common methods include just using a bolt that only has thread on the end, or a steel shaft that is pinned in at both ends.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 14-12-2007, 17:02
mattotters's Avatar
leadership/fab team
I was personaly thinking of a pillow block with out berings, have you ever seen this?comments?
Unread 14-12-2007, 17:09
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
I've seen pillow blocks, but my team has gone through the frame with an axle the past three years. I can't remember if we used bearings in our pillow blocks before then or not.
Edit: We used bearings on our 2004 robot, but we had some odd-shaped pillow blocks that year, and I can't remember how we mounted our front wheels. Can't find clear enough pictures of previous robots on CD to make the call there.
Past teams:
Unread 14-12-2007, 17:21
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
I'm actually planning on doing a bearingless pillow block style design this year (assuming the game calls for 6WD). Here's why: with a hole through the frame, you have to decide on the how much lower the centre wheel is when you make the frame; however, with a pillow-block style design, shims can be used to adjust the lowering. Since the amount of lowering is adjustable, we can then test for what gives us the best driveability. (It could also allow us to adjust the lowering before every match, but I'd rather avoid the trouble of doing that by just picking a good amount and sticking with it)
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 14-12-2007, 18:08
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
1/8" is what you want, no need to go to too much trouble just to make it adjustable.
Unread 14-12-2007, 18:11
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
How much drop you put in depends how much rock you want/need. I can't remember offhand how much 330 drops their center, or any other recommendations (I'd say 3/16, but that's way too much--more likely 3/32 or 3/64.)
Past teams:
Unread 14-12-2007, 19:08
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
We drop 3/16. It gives us great turning, but it does rock enough to be annoying.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 14-12-2007, 20:57
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
I'm sorry Im a nub, but does dead-axle have anything to do with using pillow blocks?
Pillow blocks are quite expensive on mcmaster-carr (about 30 bucks a piece)
is live-axle a more economical choice?
and with a live-axle, would you have to connect the sprocket to the shaft?
sorry for the nub questions
Unread 14-12-2007, 21:06
MrForbes's Avatar
AKA: Jim
The easiest newbie way to do it is to mount the wheel on bearings on a "dead" axle that is just a bolt thru the frame. The sprocket then bolts to the wheel.
Whether or not you need blocks to mount the dead axle, depends on the design of your frame. The kit frame has flanges with holes in them designed for a bolt type dead axle. If you use that extruded stuff then you may need to make blocks or angled plates to mount the axle.
With a live axle, connecting the sprocket you can buy hubs, most teams who use a live axle make most of the parts themselves, it's not really a newbie appropriate thing to try unless you have good help.
here are some of the hubs, the keyed and hex hole type are what you might use
http://andymark.biz/hubs.html
Unread 14-12-2007, 21:09
in between teams
AKA: Luke Van Oort
Nothing really. What I'm talking about is a block of aluminum with a hole drilled partway though (like halfway maybe) so it can hold an aluminum shaft as a dead axle. Then, the block is mounted to the robot with bolts and its height can be adjusted with shims. Not really a pillow block in the traditional sense, but similar.
Generally no. A bolt through a hole in the frame can serve as a dead axle, with live you need keyed/hex/spline/etc shafts, bearings, pillow blocks, so on.
Usually yes. If you used gears for power transmission, you'd connect those to your shaft.
Nothing to be sorry for, everyone was a newbie sometime.
Unread 14-12-2007, 21:17
M4 Sherman's Avatar
M4 Sherman M4 Sherman is offline
FRC #1662 (Raptor Force Engineering)
M4 Sherman is an unknown quantity at this point
Dead axle systems are usually lighter then the live axle, and there's less moving parts.
Also, the drop of the middle wheel on a 6wd depends on the type of wheel used.
Unread 14-12-2007, 23:08
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I wouldn't be so quick to say "usually". If live vs. dead is the only difference, then you're probably right. The axle moves in a live system, so that's one more moving part. But the live axle system I'm most familiar with has the axle itself as the gearbox output, saving several parts (sprockets and chains at least). You can just use a live axle in the same sort of application one might use a dead axle, but you get additional design options when you choose a live axle.
Unread 15-12-2007, 10:43
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
Not only that, it was a good technical question that prompted further discussion. It has been a while since we've had a good live vs dead axel discussion.
Christopher H Husmann, PE
"Who is John Galt?"
  #15   Spotlight this post!
Unread 20-12-2007, 16:11
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott3137
FRC #3137 (T-Birds)
Rookie Year: 1999
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
Last year we used shoulder bolts as axels through the frame, which worked well.
Scott 3137 (formerly Scott 358)
Drive Mobility System Kam-AL Motors 7 11-01-2006 19:17
Best Drive system rcubes85 Control System 8 12-01-2005 22:32
pic: Drive System CD47-Bot Robot Showcase 3 27-02-2003 14:11
DRIVE SYSTEM archiver 2001 6 24-06-2002 02:30
Drive System archiver 2000 6 23-06-2002 22:57
