Go to Post Gee, I wonder if AndyMark has a wedding gift registry? - KathieK [more]
Unread 14-12-2007, 19:00
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Unhappy I need help, my knowledge is outdated...
I have been out of the FIRST programming scene for a year and things have moved on
I'd appreciate if you could answer these questions so I can get up to speed on some issues were having.
I will be referring to these quotes in my question:
NOTE: To Compile 2004, 2005 or 2006 code, use MPLAB ver 7.20 and C18 Compiler ver 2.40 (newer versions can not be used)
and
Notice: The new FRC Robot Controller is not compatible with pre-2004 Operator Interfaces. The Operator Interfaces is also not compatible with pre-2004 Robot Controllers.
My questions:
  1. Is the 2006 RC compatible with 2007 code?
  2. is the 2007 code compatible with the latest c18 (i.e. newer than 2.4) and mplab (i.e. newer than 7.2) ?
  3. should I insist on installing to the default C drive? will switching drives cause problems?
  4. Basicly if I can use the 2007 code on a 2006 RC, what versions should I install?
That's It for now but i'm sure i'll have more later....
thanks!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 14-12-2007, 19:22
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: I need help, my knowledge is outdated...
1. Yes, code written for 2006 will work on a 2007 controller.
2. No, 2007 code won't work with a newer compiler. Or, atleast, results are not guaranteed.
3. Any drive should work, as long as your file names are under 64 characters.
4. See above. The 2007 RC was largely identical to the 2006 RC from a programming standpoint. There were some changes to the master code and a few other glitches per usual, but the overal code structure and programming process hasn't changed much since the big switch from 2003 to 2004. 2004 to 2005 was a small change, and everything's been the same since then, basically.
Unread 14-12-2007, 19:24
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
1. Yes
2. No
3. Maybe. It shouldn't matter as long as you don't have Hebrew characters (or any other non-English characters) in the folder path or have a pathname more than 64 characters long.
4. I'm not sure what you mean here, could you clarify?
EDIT: Darn, beat to the punch. I guess I'll leave my post here in case someone has issues with Hebrew pathnames.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 15-12-2007, 03:47
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Thanks
what I meant by question 4 was: "if I want to use the 2007 code, which versions should I use of mplab and c18? (i.e. 7.2 and 2.4 accordingly?)"
also, I can find mplab 7.2 but c18 2.4 is nowhere to be found (i only found an upgrade package...)
does anyone have a link to c18 2.4? thanks!
-Leav
-Paraphrasing JFK
Unread 15-12-2007, 04:14
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Ok I found the compiler on an old disk I had around here (in the old robovasion kit).
but let's say for future reference, how can someone get the old 2.4 version of c18?
can I upload it and link to it or is that illegal (I imagine it would be, but just checking...)
-Leav
-Paraphrasing JFK
Unread 15-12-2007, 10:25
Rookie Year: 1998
Yes, uploading the full version of C18 is illegal. There's a 60-day Student Edition trial version that's available here however. The only trick is that after 60 days, it loses access to the extended instruction set features and some other optimizations.
Unread 15-12-2007, 12:09
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
so what we got from FIRST is the full edition with all the "bells & whistles" ?
-Paraphrasing JFK
Unread 15-12-2007, 12:16
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
You need to order the following P/N from InnovationFIRST: C-BOT-COMPILER
You will find it listed on this page, cost $50.00
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 16-12-2007, 06:43
neutrino15's Avatar
neutrino15 neutrino15 is offline
plɹoʍ ollǝɥ
AKA: Jordan Perr
FRC #0694 (Stuypulse)
Rookie Year: 2007
neutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really nice
Originally Posted by lukevanoort View Post
2. No
Hold on a second. My team is currently using the c18 compiler under wine, and we are using the config.py script to generate makefiles. Does this mean I need to keep the old versions of c18 installed so that we can update older bots? Or should I just re-write some parts of 2007 code? What about our 2006 code? Basically, we still have those robots (we use them at demos) and need to be able to modify their code. How do I do this?
Unread 16-12-2007, 14:24
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
If I am not mistaken the code itself is different from year to year, but C18 and Mplab have retained the same version: 2.4 and 7.2 respectively.
so for all the controllers you need the same version of mplab (7.2) and c18 (2.4).
However the code itself has changed as far as I know....
Please someone back me up/correct me here....
-Leav
-Paraphrasing JFK
Unread 16-12-2007, 18:29
teh_r4v3 teh_r4v3 is offline
AKA: Rajeev Sharma
FRC #1511 (Rolling Thunder)
Team Role: Student
teh_r4v3 is on a distinguished road
Send a message via AIM to teh_r4v3
Yeah, the 2007 code is different than the 2006 code. However, IFI only officially supports MPLAB 7.2 and C18 2.4. I've tried higher MPLAB versions (up to 7.52 I think) and they work, although the project files are not backwards compatible with earlier versions. I haven't tried any newer versions of C18 though.
Rajeev Sharma
Team 1511 Rolling Thunder
hoojamomma?
PLEASE HELP!! Need help programming arm?? amirjpl Programming 12 15-03-2007 15:11
I need help. Please. Misdreavus 3D Animation and Competition 6 15-02-2007 19:51
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
