Go to Post I think the new smoke cost about $ 189 from AndyMark. - ebarker [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 17-12-2007, 16:02
aksimhal's Avatar
aksimhal aksimhal is offline
AKA: Anish
FRC #1123 (Autodidactic Intelligent Minors)
aksimhal is an unknown quantity at this point
Send a message via AIM to aksimhal
Inventor 2008 FirstBase Tutorials
Hi! Has anyone got the online tutorial for Inventor 2008 called "Introduction" to work? I've installed Inventor 2008 and the "Datasets" but what exactly am I supposed to do from there?
Thanks a million,
Anish
Unread 17-12-2007, 16:17
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: Inventor 2008 FirstBase Tutorials
I beleave the instructions for the Tutorials are in the menu Help> Tutorials
Thanks a million,
Anish
Unread 17-12-2007, 18:41
aksimhal's Avatar
AKA: Anish
Hi,
Sorry for not being specific.
Exercise Setup
These tutorials are designed so you can follow the step-by-step exercises onscreen. After launching the onscreen exercises, you might need to alter the size of your application window to align both windows.
1. Start the application.
2. Select a module and exercise from the list of modules and exercises in the pane on the left.
3. Click the Start the Exercise button to launch the exercise window
4. Resize the application so that you can still see the exercise window.
5. Complete each exercise using the application.
This is from the FirstBase website. Where are the modules in Inventor?
Thanks,
Anish
P.S. Will it be necessary to upgrade to Inventor 2008 to use to 2008 KOP Inventor parts?
Unread 17-12-2007, 21:20
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
If past years are anything to go by, this year's virtual KOP will be Inventor 2008 files. Assuming that is the case, you will need Inv 2008, or have somebody with Inv 2008 save them as STEP for use with earlier versions.
Pete Kieselbach
Unread 18-12-2007, 15:01
aksimhal's Avatar
AKA: Anish
Hi!
Thanks for the information about the Inventor KOP! Have you tried using the FirstBase tutorials (especially the first one)?
Thanks,
Anish
Unread 26-12-2007, 19:30
aksimhal's Avatar
AKA: Anish
Hi!
Has anyone got the Autodesk FirstBase Tutorials to work?
Thanks a million,
Anish
Unread 15-01-2008, 13:02
grsnovi's Avatar
grsnovi grsnovi is offline
Autodesk Inventor Team - Portland,
AKA: Gary R Smith
FRC #2542
grsnovi will become famous soon enough
Thanks a million,
Anish
I think what you are supposed to do is this:
Introduction - this "step" gives you the button needed to download the data sets you'll need for the rest of the examples - but you don't really "do" anything yet.
Then you need to work between the web browser window, select (for example) the next one down: "Autodesk Inventor and Robot Design"
When that comes up, click the button that says START THE EXERCISE which will launch a "tutorial" window that you ought to be able to slide over next to the Inventor window.
You'll proceed through the various exercises and work on the files that you downloaded in the Introduction.
Inventor delivers a bunch of tutorials that you could do without downloading any of this stuff. From the main HELP menu, pick HELP TOPICS (it should be the first one down) then after the Inventor help page opens up about mid-way down the list pick TRY IT TUTORIALS
This will open a new window with a listing of tutorials. Look at the section labeled: Basics and try starting with Creating a Part
Unread 15-01-2008, 17:44
aksimhal's Avatar
AKA: Anish
Hi!
Thanks so much. I just got it work.
Thanks,
Aksimhal
**FIRST EMAIL**/The Autodesk FIRSTbase site has re-launched for the 2008 FRC Season! Mark McLeod FIRST E-Mail Blast Archive 0 20-11-2007 09:20
**FIRST EMAIL**/Autodesk FIRSTbase to Re-launch for the 2008 FRC Season! Mark McLeod FIRST E-Mail Blast Archive 3 24-10-2007 14:06
Inventor 2008 // last thread EVER about chains in Inventor? Dan Zollman Inventor 10 10-07-2007 20:01
Good Inventor Tutorials/ Book Nitroxextreme Inventor 6 14-06-2005 23:23
Inventor Tutorials petek Inventor 1 17-01-2005 21:48
