anyone know a good way to make realistic trees?
im working on setting up some scenes for this year's animation chalenge. any help would be awsome. and i dont really want to use the ones built into 3ds max. |
Re: Trees
Do you not want to use the trees that come with Max because you don't like the way they look or because you think that would be "cheating"?
I think it would be okay to use all the tools that come with Max, including the trees. But a couple years ago we created trees by just making some planes and applying tree photograph texture maps. The maps had a transparent alpha so the trees didn't look square. We used a coulple different maps and resized & mirrored them to add a little variety. The planes were at a right-angle to the camera so they didn't look flat. If your camera moves it's more of a challenge. You could use 2 planes at a right-angle (a cross from the top view). That sort of looks good to a moving camera. |
Re: Trees
Did a Google search and the only ones I found cost like $500. They did look very nice, but that isn't included in our budget |
Re: Trees
any ideas? |
Re: Trees
First off, Get it out of your head that you can make realistic looking trees in time for the AVA award. I'm not saying that you don't have the capability, I'm saying that the time frame that autodesk gives you, is too short. Realistic looking trees take way way way too much time to make. Is it possible? yes, Is it worth it? My answer is no, because you would have spent all of your time on a backgound object and no time on your foreground. When i say realistic looking trees i mean that you have the bark, every individual branch, every leaf, the color exactly, the ones that they make at dreamworks or pixar. They have teams of people working non-stop around the clock to generate those types of trees. It's very hard to have that kind of manpower in a animation team in FIRST. If you are smart about it, you can make some pretty darn good looking trees. Think of your style of your animation, If you have a cartoony characters but realistic looking trees, Wont they look out of place? as opposed to cartoony trees and cartoony characters? Check out some trees in some our animations. AVA 2007 ![]() They arn't realistic looking but they fit the syle of the animation. As does this picture with these trees. ![]() You can clearly see how the trees were made. It works because these trees are in the background and you dont need to see every single individual leaf. Last edited by BuddyB309 : 21-12-2007 at 19:02. |
Re: Trees
I'm going to have to disagree on this with you buddy. It's quite simple to make good looking trees in not a whole lot of time (about an hour). Here is a great tutorial for it http://3dm3.com/tutorials/tree/ I will warn that they can get pretty high poly so keep that in mind.
Re: Trees
Now if your tree is in the foreground, or it is the central focus of the animation then by all means go nuts! If you want a to make a tree character or a shot of a specific tree that you want to show the viewers then pour as much detail into it as necessary, but the trees in the background should be basic. Because they are only background elements, that only add to the atmosphere of the scene. |
Re: Trees
I agree completely that it is not necessary in all situations, but am merely stating that it does not actually take long to make them. Oh buddy by the way are you using camera angle dof in that or are you just using the lens effects dof. Looks pretty nice for the lens effect dof.
Re: Trees
Re: Trees
Makes sense, very useful information, but would that get messed up by transparent elements in front of the object. It is done essentially the same way the camera lens effect is done in max (which is also incredibly fast), but the camera lens effect gives a lot of problems with transparency and reflections and such.
#11
Re: Trees
Re: Trees
Thanks, ya I'm good at modeling and texturing, but when it comes to everything else, I still need to do some research.
#13
Re: Trees
Pete you didnt even talk about my animation? We had a scene with a lot of trees, we used the Max trees. It was 5.8 million polys. Max trees eat render times and poly counts.
#14
Re: Trees
Tom, your talking about Eco bot. Your sky dome was a sky "box" I rest my case with 3ds max tree not looking like any trees. You can produce better dreams than what comes with max.
| Real or Fake? Christmas Trees, that is. | A. Leese | Chit-Chat | 35 | 19-12-2001 23:58 |
