Go to Post It is usually the simple things that get you. - Andy Brockway [more]
Unread 19-12-2007, 13:01
JimGRobot JimGRobot is offline
AKA: Jim
FRC #1388 (Eagle Robotics)
JimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really nice
"Telephoto" lens for CMUCam?
I am looking for an optical method to increase the size/resolution of a target, has anyone seen a lens that will replace or snap over the existing one to do this?
Thanks,
Jim
Unread 19-12-2007, 13:52
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: "Telephoto" lens for CMUCam?
I have never seen one but that sounds like a really good idea!!!
Unread 19-12-2007, 14:24
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Thanks,
Jim
Jim,
I am searching the docs for a good answer but I think that the camera comes under the "do not modify" list. I have not found anything in the rulebook yet. At anyrate, the focal length of the supplied lens give enough of a field of view to track the intended target(s) and the GDC keeps this factor in mind when working on the game and field components.
For other applications, I have seen vendors who have other lenses for this camera. I you search for CMUcam, you will find a number of outlets that also sell accessories. One of them is bound to have a lens. The current lens gives about a 60 degree viewing angle in the horizontal and less in the vertical due to the 4:3 aspect ratio.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 19-12-2007, 14:27
FRC #1360
does it count as modifying if you have a detachable len sitting on it???
Unread 19-12-2007, 14:29
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
I don't see why that would be the case. It's an off-the-shelf component just like anything else.
Unread 19-12-2007, 18:24
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Ooooooo-kay. Through some deduction and a lot of googling, I have determined the style of the CMUCam lens to my satisfaction. The camera board is a C3188 evaluation module for the OmniVision 1/3" OV7620 Sensor. As such, I think the actual mount on the board is the V-LH4-IR listed here.
So the thread is M12x0.5 and any 1/3" format lens with a M12x0.5 thread should work just fine. This is apparently also known as an "S Mount" lens. For instance, the same folks predictably carry several compatible lenses. Here's a bunch more. Note that 1/2" lenses will work just as well, and you don't have to worry about the IR filter unless I'm wrong about the current mount having an integral one.
Also, here and here.
Personally, I'm intrigued by the variable focal length lenses, though they would obviously necessitate extra servos and such to really take advantage of them.
Unread 24-12-2007, 11:19
AKA: Jim
Thanks for everyone's quick and thorough replies.
This time my particular application is not FIRST related, so I don't have any rule issues. Also, I don't need an adjustable focal length, just a longer one.
Anyway, the links that were posted help a lot...
Thanks to all,
Jim
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
CMUCam blink test "blinktst.ic" mzainon Programming 1 22-04-2005 16:20
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
