Go to Post Also, If I am not mistaken, the name indicates that your robot is female :P They're all female... like cars, ships, and airplanes. - JVN [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 16-02-2008, 20:46
jmu465 jmu465 is offline
FRC #2077
jmu465 is on a distinguished road
Re: Problems with IR Board
Later in the thread you say that you powered teh board from the back-up battery... check that the back-up batter is charged. The IR board has a 5v regulator on it so it needs at least 7V to "power up" the regulator.
A dead (dying) battery sounds like a likely villian.
Originally Posted by keen101 View Post
"I broke" our board today.
It was working fine, and then all of a sudden.... nothing worked. It suddenly got quiet.
I suspected the 5V 78LO5 was bad, so I asked my dad to help me diagnose the problem. Sure enough the regulator was bad. So my dad helped me find a suitable and more robust replacement. We put in a new regulator, and now it works great again!
...My advice to anyone with a quiet board, is to check the regulator.
Unread 20-12-2007, 14:05
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
Originally Posted by Kevin Sevcik View Post
You could measure across pins 2 and 3 of the big whit connector with negative on 3 to check as well.
Anyone have an opinion as to if it would be advisable or not to bypass the regulator and apply a regulated 5VDC to pins 2 & 3 of the white connector to test the remainder of the board?
BTW: Our board was sitting on the anti-static envelope as well when we first powered it up. I have always done such and never knew that to be a problem. If that was the cause then I guess it was my fault. Never knew that to be a problem but I will never do it again, that's for sure. I have emailed Ben at Diversified Systems inquiring about obtaining a repair or replacement. I will post what I find out when I hear back from Ben.
Edit: Thanks Ben. It looks like you beat me to the post!
Unread 20-12-2007, 15:26
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
If the 12V input were grounded somewhere I think this would be a bad idea. However, since the only ground path available to it is through a capacitor, I don't think it would make anything explode. and since your regulator's apparently dead anyways I don't know that saving it from anything matters much now unless FIRST or Divsys are planning some forensics on it.
Unread 20-12-2007, 20:14
DonRotolo's Avatar
Back to humble
FRC #0832
I completely agree: IF there really is any kind of problem, I have complete confidence that FIRST and DSI will make it right.
But, WE have to help! By that, I mean this: Unless you are posting a fact, PLEASE label it as an opinion. At the very beginning of the BaneBots issue, there was a LOT of "noise" from people speculating, guessing an just plain writing what they thought was happening, but with little basis in fact. It was not until certain engineering folks started documenting facts using the scientific method (and photographs) that we got to the "root cause" and enabled BaneBots to address it.
Again: Post facts please, not opinion. If you don't know what happened, then just post your factual observations. If you speculate, then label it as such.
Tally so far:
358: LEDs flash during learning. After, either error light or nothing
456: Totally dead, 78L05 has no output
1357: Worked, then 78L05 fried. Maybe anti-static bag?
2144: Board works, LEDs do not light
2199: Error LED lights sometimes, not "0" (learn loop) LED
FYI: Current advice is NOT to repair the board if you suspect an issue, instead report your observations (to FIRST?). The regulator is a 78L05 in the standard TO-93 package, available almost anywhere (even Radio Shack - PM me and I'll mail you one). +5 VDC can be supplie, but the PIC will fry at 5.5, VDC, so try it only if you are really certain of your power supply...
Thanks,
Don
Unread 29-12-2007, 12:35
sayso_411's Avatar
sayso_411 sayso_411 is offline
10 Years of Sparky!
AKA: Shaav
FRC #0384 (Sparky)
Rookie Year: 2007
sayso_411 can only hope to improve
Red face Re: Problems with IR Board
Hmmm... thats funny because our IR board worked at first try with a Toshiba TV remote (cant tell but probably something wrong with IR board)
Unread 05-01-2008, 21:57
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
get a board at all
does anyone know how to get a board, ours got lost, can you buy them, should i call first or ifi?? any help would be get
wendy holladay
mentor team 1912
Unread 07-01-2008, 02:41
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Re: get a board at all
wendy holladay
mentor team 1912
I'm not sure. I'd like to get a backup one as well.
I may have to start emailing diversified systems, as IFI does not seem to carry them.
Unread 09-01-2008, 22:03
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Rookie Year: 1999
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
We had a burning smell and got no response. We used a 9V battery.
We confirmed and doubled checked that the wiring was done correctly.
I did the wiring myself and had it doubled check by another Mentor.
We did find the the voltage regulator was lose when we first smelled it.
So we are assume the voltage regulator is fried, faulty or installed faulty.
SO if anyone knows how to get a replacement, or repair let us know.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 10-01-2008, 00:58
keen101's Avatar
Ubuntu Linux User
you just need to somehow find a replacement 5V regulator and replace the old one.
I recommend using a solder sucker to remove the old one. as for finding a 5V L805 or equivalent... I have no idea where to find one. I just salvaged one from some old board lying around. I looked at Radio Shack, but I did not see any.
I have already fixed our board twice. It was the 5V regulator both times.
It's too bad FIRST did not design the board with a diode to prevent accidental reversed polarity.
Unread 11-01-2008, 11:02
Phalanx's Avatar
Rookie Year: 1999
Is there any major reason that a 7805 From Radio Shack couldn't be used as a replacement voltage regulator?
http://www.radioshack.com/product/in...rt&tab=summary
The only difference I can see that the factory LM78L05 is limited to 100mA and the 7805 from Radio Shack is 1A. Would this be a bad idea?
Thanks,
Michael
Unread 11-01-2008, 11:08
keen101's Avatar
Ubuntu Linux User
hmmm......... it might have been the 7805 one, that I used. I can't remember, and I don't have my board with me right now.
Unread 11-01-2008, 13:21
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
You'd have to make sure that the pins on the connector would actually fit in the holes for the regulator, but other than that, it should work from an electrical standpoint.
However, I don't know if this would be allowed by FIRST rules, so I would contact them first.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 15-01-2008, 04:38
dlotts dlotts is offline
FRC #1418 (Vae Victus)
dlotts is an unknown quantity at this point
Send a message via ICQ to dlotts Send a message via AIM to dlotts Send a message via MSN to dlotts Send a message via Yahoo to dlotts
Our board worked for at least 30 minutes. Then the next time we tried it appeared completely non-functional, with no LED's lighting. Maybe the ground and plus voltage got switched one time, we don't know.
We tested the voltage at the inputs, and they were correct.
Then we tested the voltage across the PIC chip at the Vdd and Vss pins. It showed a consistent 0.36 volts -- way lower than the expected 5.0V. We read the same voltage between the ground and the output of the regulator.
We de-soldered the regulator, and replaced it with a larger 7805 regulator that we had on hand, probably 1 Ampere. We used short pieces of wire so we didn't have to make the larger part fit.
Since we'll probably want to have a second one on hand at the competition, we figured we didn't have much to lose by attempting to repair it.
Then the school kicked us out and we didn't get much chance to clean up our solder and try it.
I'll let ya know how this worked out later.
MrLotts.
Unread 15-01-2008, 07:24
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
MrLotts.
This sounds exactly what happened to us. Please tell us if you get it working. Also, I called FIRST yesterday, and they said they sent a shipment of the IR boards to Innovation First, and that they should appear some time today. Whether or not this is true, I'm going to keep on eye open for them.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
  #15   Spotlight this post!
Unread 15-01-2008, 12:03
keen101's Avatar
Ubuntu Linux User
Thanks,
Michael
If you can get it soldered to the board, then I think it will be fine. I think it's perfectly legal, since you aren't changing the function of the IR board. It is certainly a beefier regulator, but it should work.
Learn C, C++, and Java with new board game. Elgin Clock Programming 8 04-11-2005 13:28
problems with G22 JMH Electrical 2 19-01-2005 20:52
Problems with referees?! LauraN General Forum 16 22-03-2004 17:05
School Board Problems Matthew_H General Forum 47 16-03-2004 18:32
