| View Poll Results: What's the status of your IR Board? | |||
| Ours works fine |
57 | 72.15% |
| Worked but we broke it |
6 | 7.59% |
| Partial operation but gets the job done |
2 | 2.53% |
| Partial operation but not the important part |
6 | 7.59% |
| No response at all |
10 | 12.66% |
| Multiple Choice Poll. Voters: 79. You may not vote on this poll | |||
Re: Tally of Working IR Boards
I put "Partial operation but gets the job done"
just because it worked fine before, and seems to work fine after repair. I did test the outputs before with a multimeter. I still have to test them now after repair. I'll report back when I've done that. |
Ours works as advertised .......
No issues ...... ![]() |
The Robo-Lion's (2199) IR board doesn't work.
The board turn's on an the error LED turns on. When we try to program it ( giving it power after holding down the program button and holding the button for 2 seconds as indicated by the manual), the LED turn's on (and then off when we release the button), but doesn't flash to indicate that it is ready to program. The error LED doesn't flash to indicate that there is a problem at all, but there is obviously a problem if it can't program. Several people have tryed to getting it to work but no sucess. We think it is a defective one, but if you know otherwise tell me. Thanks, Aarnat |
richardmcc2,
Once we release the programming button, everything stops: no LED's light or blink or anything. Last edited by Aarnat : 24-12-2007 at 12:58. |
DigiKey or Mouser (online), unless you are fortunate enough to have a real electronics store in your area (Radio Shack doesn't count).
I jumpered the on board regulator, and now feed the board with 5 volts. Works fine now, and worked fine before I accidentally reversed the polarity.
Our first IR board was DOA, it seemed that the 5V regulator got fried before it even got to us. We got another one, and now it works great. We used the remote on it from 50 ft away, which was nice.
I couldn't help but notice in your video the output led's flash repeatly. The operation of the IR is when it recieves a learned command, it toggles an output for 100msec. Your outputs in your video flash. Is that because: 1. Your remote control is repeatly sending a signal to the IR controller? 2. Your operator "thumb" is pressing on the remote control repeatly? The remote control we are using only sends one IR command per-press of the button, even if you hold it down for any length of time. Just curious... BTY, our board works great out of the box. |
#10
I would assume it's repeatedly sending the signal. I have tested two different remotes with our board. One was a cheap DVD remote that only sent the signal once. The second repeatedly sent the signal. If you read the IR manual it talks about using a remote that repeatedly sends the signal. |
#11
Ours did work, but now magically doesn't. We have no idea why. Would it be best to contact FIRST or buy a new one?
#12
Has anyone used it for auto-mode changes yet? Perhaps on an old bot?
| Game Hint Tally | T3_1565 | Rumor Mill | 137 | 29-12-2007 23:11 |
| Camera Boards | Inoperational | Programming | 6 | 20-01-2007 12:57 |
| OI Boards? | Jake M | Robot Showcase | 1 | 28-11-2006 20:02 |
| Cost Tally | Andy B | Kit & Additional Hardware | 1 | 10-02-2005 10:54 |
| Control Boards | tenfour | General Forum | 3 | 01-03-2004 20:01 |
