Go to Post It shouldn’t be about whether or not you think it’s easy or not, it’s about whether or not you think the effect of the change would be a positive step for our country. - Bill Gold [more]
Go Back   Chief Delphi > Technical > CAD
Unread 23-12-2007, 23:53
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
Team Role: Leadership
Rookie Year: 2007
team2061 will become famous soon enoughteam2061 will become famous soon enough
Need pictures of chassis for 6WD
My team is trying to design a chassis for the 2008 season but needes ideas. Anyone with CAD pictures or any pictures of chassis for a 6WD is encouraged to post them. Thank You
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Unread 24-12-2007, 00:37
CraigHickman
Posts: n/a
Re: Need pictures of chassis for 6WD
Totally. Designing a 6WD is fun, and a very useful thing.
Name:	6in wheel base.jpg
Unread 24-12-2007, 00:55
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
1726's: Fiberglass I-beam and C-channel with ifi wheels and AM shifters
http://www.chiefdelphi.com/media/photos/26813
Unread 24-12-2007, 01:05
Billfred's Avatar
Billfred Billfred is offline
I don't have CAD pictures, but you don't particularly need them for the 6WD designs I've had a hand in.
The first stab at 6WD was in 2006, with Chomp. We used the 8" Skyway wheels in the kit along with a pair of 8" IFI wheels, all driven with two small CIMs in the Kitbot transmission of that era (an option still available is the AM Gearbox from AndyMark). The combination allowed for nice turning and was plenty solid, although ramp climbing was an issue. (The issue never really was diagnosed.)
The lessons learned from Chomp (along with some funds to facilitate it) led to Uppercut. This year, we used the AM FIRST Wheels from the kit of parts, cut the rubber tread molded on (burning myself in the process), and riveted on incline conveyor belt from McMaster-Carr. We used one large and one small CIM driven by Gen2 AndyMark Shifters. We used the pneumatic shifters for the added shift speed compared to servos, and because we'd been learning pneumatics in the off-season; the large CIM was used because one of the small CIMs was needed elsewhere. We also used JVN's drivetrain calculator to figure out the sprockets needed to give us the speeds we desired. (In theory, about 12 and 5 feet per second.)
The result was the best drive system all-around from four years of trying, though it wasn't without its flaws. Of note:
1) The kitbot loved to lose nuts and bolts. I'm hoping we'll have the ability to rivet by Kickoff.
2) In the absence of all the nuts and bolts, enough abuse on the front bumper will cause it to bend mercilessly. (As our arm never worked through Palmetto and Brunswick Eruption, we played a lot of defense.)
3) We should've mounted the AM Shifters on the side with more weight (the side with the tower). We broke the screws in the left center wheel on Friday at Palmetto, meaning we couldn't power the left center or rear wheel. Only the front wheel would get power from the gearbox, and it was off the ground for all the weight in the back. Were we to adapt this design for 2008, I'd move the gearboxes to the heavier side. (Granted, this makes the weight distribution a little worse; you can move other things forward if need be, though.)
4) We used the frame stiffeners in the kit to mount our gearboxes on Uppercut, not realizing that they blocked the chain path. We fixed it with idlers on Uppercut, but I'd rather find another way in the future to eliminate some weight and complexity. (Flipping the gearboxes upside-down from how we mounted them may fix the problem; I don't have a means of checking.)
That's the business-major version of the various 6WD setups of the greater Columbia area. There are others who will have plenty more to offer. Good luck!
Unread 24-12-2007, 11:43
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
I second that endorsement.
A couple of naked photos show the chassis the best, for what they're worth.
We later replaces the mock-up skyways shown with AM performance wheels. We also ran all of our chain in the frame rails to keep it out of contact with other things and to provide a larger sepeartion of the bearings for the cantilevered axles. Cantilevered axles were chosen to simplify changing wheels out... we treat treating as a consumable item and swap twice a day or so. All of the axles were mounted in sliders so that the center wheel drop was adjustable and the corners adjusted the chain tension.
The only real suggestion that I have is if you don't have a solid idea for the chassis that you want to build within a couple of days of kickoff, you may want to punt to the kitbot and iinvest the time in you manipulator instead. Week 2 is not a good time to be trying to learn the spreadsheet Billfred mentioned.
Mark
Brick walls are for other people. - Randy Pausch
Unread 24-12-2007, 14:35
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Rookie Year: 2000
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Thats a picture of the 1902/1369 chassis from last year, waterjetted aluminum. Everything was riveted or bolted together. Integrated AM shifters
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 24-12-2007, 14:51
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Here's some pictures of Team 228's 2007 drivetrain and chassis:
The main frame members were 0.125" aluminum fabricated on a CNC sheet metal turret/punch machine. We used Banebots (it wasn't until after we had our drive train powder-coated that we found out how horrible their quality was) direct drive onto the rear wheel. All axles were live, and the wheels were custom-machined out of blocks of aluminum to 5.5" in diameter.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Which is Better metal or composite materials for the chassis Jared Rillings Rules/Strategy 3 13-01-2007 11:39
4WD vs 6WD SleeveofWizard Technical Discussion 3 12-01-2007 12:03
6WD chain path Bill_Hancoc Technical Discussion 18 13-12-2006 17:08
6WD? Alex Cormier FIRST Tech Challenge 14 17-04-2006 22:10
4wd vs 6wd? Yov Technical Discussion 22 06-01-2005 00:09
