Go to Post I'm a bit wary about playing on the new fields, however, because of the Carson/Carver/Hopper/Tesla Curse. I hear no alliance from those divisions has ever won championships. - [more]
  #16   Spotlight this post!
Unread 27-12-2007, 03:03
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
Re: How much metal to get?
My experience has been with inch square aluminum tubing with a 1/8th wall thickness. 6061 is the default alloy of choice for the majority of FIRST applications, tube or plate. It offers good strength characteristics while being weldable. It's also very common which increases your options for quantity and shape and decreases lead time. There are probably some places where other alloys would be better suited, but few where 6061 is a bad choice.
Welding will toast the heat treatment. I've seen very few clear cut cases of the joint failing because of this, but it's worth considering.
Polycarbonate can often be substituted in place of aluminum plate where stiffness is not critical. Both materials weigh about the same but the plastic is easy to worth with, non conductive, transparent to light and radio and a whole litany of other pros.
Plywood is another good substitute for aluminum in some cases. It is again easier to work with, non conductive and with quality wood very tough. It is cheaper and can be easily found. I've often used it to 'prototype' aluminum parts, only to find that the wood works perfectly well. It can quickly be replaced modified or glued back together if need be.
Just don't invest your team to heavily before the season starts. For all we know aluminum may be banned this coming season.
-Local
How much traffic does your team's website get? artdutra04 Website Design/Showcase 10 08-02-2006 15:21
How much sleep are you going to get??? ttedrow General Forum 34 11-01-2004 02:27
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
How much sleep did YOU get? Erin Rapacki Championship Event 24 21-05-2002 15:43
