Go to Post Belts are a fine way of transferring power in a robot. Like chains, gears, drive shafts, viscous couplings or any other means of transmission they require some care and attention on you're part. But no one said this robot stuff was going to be a cake walk. - Andy A. [more]
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Unread 26-12-2007, 03:36
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
New C18 3.0+ Compatible FRC Code
I've created C18 3.0+ compatible code and libraries for the IFI FRC robot controller. At this point the code is pretty solid and free of bugs. If interested, the code can be found here:
http://kevin.org/frc
Remember this is experimental code, so please do me (and everyone else who might use this code) a favor and let me know if you run into any bugs. Thanks.
1/6/08 Edit: You need MPLAB 7.21 or greater to use the 3.0+ compiler. You can download the latest version here:
http://www.microchip.com/stellent/id...&part=SW007002
The student and upgrade versions of C18 3.10 (don't use 3.15) are here:
http://www.microchip.com/stellent/id...&part=SW006011
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
