Go to Post Isn't that sort of like asking "is that an African or European swallow?" - dlavery [more]
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Unread 26-12-2007, 03:36
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
New C18 3.0+ Compatible FRC Code
I've created C18 3.0+ compatible code and libraries for the IFI FRC robot controller. At this point the code is pretty solid and free of bugs. If interested, the code can be found here:
http://kevin.org/frc
Remember this is experimental code, so please do me (and everyone else who might use this code) a favor and let me know if you run into any bugs. Thanks.
1/6/08 Edit: You need MPLAB 7.21 or greater to use the 3.0+ compiler. You can download the latest version here:
http://www.microchip.com/stellent/id...&part=SW007002
The student and upgrade versions of C18 3.10 (don't use 3.15) are here:
http://www.microchip.com/stellent/id...&part=SW006011
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
