pic: Front / Rear bearing saddles rev 2
Re: pic: Front / Rear bearing saddles rev 2
That looks fairly similar to a globe motor mount I made last year. Those little holes were a real pain in the drain to line up.
nice!
So are you machining that out of a solid piece of aluminum or are you just going to bend some 5052 or 3003?
I am open to suggestions and we in fact are very much dependant upon a machine shop to help us with this project. I don't have any experience bending anything other than sheet metal. Does one need a hydraulic bender to make the 90 degree bends in the 5/16" aluminum?
Also, what types of machines would your machine shop be able to provide? The types of machines they have can greatly affect how you design your parts; if they had a sheet metal turret/punch or a waterjet, you could design that entire bracket to size out of 0.1875" or 0.125" aluminum and have it bent to 90º. Then to increase the thickness needed for a flush bearing fit, you can just make a second small plate that goes around the bearing hole and is bolted to the main bracket. But if they have conventional milling machines, it's hard to find extruded aluminum in fractional sizes above about 2.00", so they'd have to mill it out of a solid block of aluminum, which would drive costs up if it's not being donated to your team. Last edited by artdutra04 : 30-12-2007 at 16:40. |
, It can be hard to get it accurate but it's a lot of fun. So long as you make it hug the frame member tight, you can then go back and cut the bearing holes to fit. |
Now that I have my design,
To make machining easier, what if I made this a three piece bolt together assembly? It would have two identical side plates and then the top piece. Maybe four tapped holes for #8 or #10 machine screws or clearance holes for the same with nylon lock nuts at the end of 2" bolts... I wouldn't know how to calculate the bolt strength needed to deal with the loads. |
#10
When my father and myself were working on the Mountain Dewbot, we machined a bunch of brackets similar to the one in this thread out of 0.25" aluminum plate, tapped and threaded for 6-32 hardware to hold it square, and had the seams welded. As long as you bevel the edges (after tapping) where they'll weld, you'll get good penetration and have a strong joint. |
#11
I like this idea. Since I don't have clearance for welded material on the inside seams you are suggesting that we chamfer the edges that will butt together so that the weld will have a void to fill and hold it together.
#12
Screws are not good for holding locations. You will have enough play in your pieces that if you don't get everything lined up, you could easily end up with your bores not being concentric after welding. |
#13
) Here's a picture of the brackets from the Dewbot that I mentioned in my previous post. ![]() |
#14
Another alternative is to weld the three pieces first and then do all your machining. This allows any warpage or misalignment to be machinined out of the bracket. Decide on your main datum plane and dimension off this for the machining.
#15
Those little holes are actually tapped for a machine screw and washer. The intent is that they will capture the flanged ball bearing. I uploaded the wrong file. The final version has a 0.500 inch fillet to round off the corners on the bottom.
| pic: Rear view of our 07 'bot | Cody Carey | Robot Showcase | 7 | 16-02-2007 12:29 |
| pic: Team 207's Rear drivetrain | Metalcrafters | Robot Showcase | 2 | 21-02-2006 22:51 |
| pic: 237 rear window sticker | Jay H 237 | Extra Discussion | 2 | 28-02-2005 12:06 |
| pic: Team 870 Rear Drive Train | CD47-Bot | Robot Showcase | 2 | 27-02-2003 00:22 |
| pic: 857 rear view programming | CD47-Bot | Robot Showcase | 1 | 25-02-2003 22:24 |
